Author Topic: Suzo Inductive Joysticks, the full story...  (Read 19067 times)
Re: Suzo Inductive Joysticks, the full story...
« Reply #40 on: March 29, 2006, 11:22:12 am »
Any progress here?  I'm about to drop an Inductive into a JAMMA cab, would be so much more valuable to have a soft 4/8 way switch method.
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #41 on: May 03, 2006, 10:33:48 am »
Does anyone know what kind of potentiometer (linear 500 ohm, etc..) the suzo uses?  I'm going to be setting these up in my cocktail soon, and wanted to add a panel mounted potentiometer to my cab...
Level42
« Reply #42 on: May 13, 2006, 01:26:54 pm »
Honeslty, I've found a setting that is quite good for both 4 and 8 way. It is not perfect however. every now and then, I hit a wrong direction on Ms.Pac Man.
So I too am interested in getting this done. It should be pretty easy. First find the perfect setting for 4 way, measure the pot's' resistance (needs to be soldered out first 1).
Then back in again and measure again for the 8 way setting.
Than make a switch and use resistors that are as close as possible to the measured values, or use a second pot.
In an ideal world, the software (mame/mamewah) would know if the game is either 2,3,4 way or 8 etc. and switch over the stick resistor value automaticaly (using a small relay).
I can do the electronics stuff, but not the software part.
