Author Topic: Rotating CP wire twist  (Read 2077 times)
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« on: August 23, 2005, 12:57:54 pm »
How to you stop the cp wiring from twisting itself off of it's connection points with a rotating cp?
Do you simply limit the rotation to so far one direction by some sort of detent and stop on the axle?  Or is there hardware that will allow you to make electrical connections at the end of the axle that will spin?
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
88mph
  • Last login:July 30, 2018, 12:17:48 pm
  • I need fuel!
Re: Rotating CP wire twist
« Reply #1 on: August 23, 2005, 02:05:17 pm »
If you look at a lot of the rotating panels out there, you will notice that they don't spin freely in a circle.  Rather, they increment a certain amount in one direction, and a certain amount in another.  That is to say, they rotate about an axis, but don't make multiple revolutions about the axis.  With such a setup, you could easily run one cable or a bunch of wires back to your computer or encoder as need be.
Still, there are ways that a freely rotating panel could be done.  You could make panels with wireless controllers built into them and rotate them all the live long day.  It would be expensive, and would probably be a pain with the batteries and all..
Also, there are things known as rotary feedthroughs.  I have a leslie speaker system that consists of speakers that spin about an axis.. this gives a great effect when playing organ music.  Anyway, they get the wires in there somehow.  Of course, running a few speaker wires is much easier than running a ton of control wires.
Later,
-88mph
« Last Edit: August 23, 2005, 02:08:44 pm by 88mph »
rdagger
« Reply #2 on: August 23, 2005, 02:38:32 pm »
By using USB you can usually run a single USB line to the rotating CP.
« Last Edit: August 23, 2005, 02:46:11 pm by rdagger »
Mark70
« Reply #3 on: August 23, 2005, 04:18:05 pm »
http://www.mercotac.com/html/830.html
these things?
My brothers in robotics.  Going to ask him if there's an affordable solution.
Pik4chu
  • Last login:April 09, 2012, 01:35:17 pm
  • So what was I supposed to put here?
« Reply #4 on: August 23, 2005, 06:55:37 pm »
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« Reply #5 on: August 23, 2005, 07:23:34 pm »
If you used a wireless keyboard and mouse hack you could get by with only two wires to supply power only.
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
