Author Topic: Need Help with Auto Hot Key Script AHK  (Read 2595 times)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« on: August 21, 2005, 08:49:52 pm »
Since Howard is on a leave of absence this week, we can rejoice, I would like to solve the pause problem he was having in his Johnny 5 AHK script.  When using mamewah, the J5 AHK script would tell Johnny 5 to start and be active when "P" is pushed, and exit when "P" is pushed again.   That allows the game player to see the controls for the game when paused.  The problem that is arising is that the script is not waiting long enough to again press "P", so mame is not getting unpaused like it should.  So here is the question:
In the script below, what can be added to the "P" command to give mame the time needed to unpause?
~P up::
   If ScreenState =1
      send, {Escape down}
      send, {escape up}
      SetTitleMatchMode, 2
      SetTitleMatchMode, slow
      WinActivate,MAME
      WinMaximize,MAME
      WinActivate,MAME
      ControlFocus, ,MAME
      send, {p down}{p up}
      ScreenState=0
   else
      J5=Johnny5.exe %1% -cloneof %2%
      Run,%J5%, G:\Development DON'T ERASE\sources\Controls Viewer3\, max
      ScreenState=1
return
~Escape::
if ScreenState=1
      WinActivate,MAME
      WinMaximize,MAME
      WinActivate,MAME
      ControlFocus, ,MAME
      ScreenState=0
else
   ExitApp ; Assign a hotkey to terminate this script.
return
Tiger, maybe you could help clarify what's going on here. Also, the official thread about this AHK can be found here:
http://fe.donkeyfly.com/forum/index.php?topic=162.0
« Last Edit: August 21, 2005, 08:52:10 pm by mccoy178 »
Tiger-Heli
    • Tiger-Heli
Re: Need Help with Auto Hot Key Script AHK
« Reply #1 on: August 22, 2005, 07:45:44 am »
No more than what I told you privately, except the following:
The script needs the following changes (suggested by 2600)(with the version of Johnny posted Saturday in the FE Dev forum)(data in red needs to be modified for your version:
#SingleInstance force
#Persistent
; The asterisk prefix makes the remapping more complete on XP/2k/NT. For 9x systems you can remove it.
~P up::
   If ScreenState =1
      send, {Escape down}
      send, {escape up}
      WinActivate,%Title%
      WinMaximize,%Title%
      WinActivate,%Title%
      ControlFocus, ,%Title%
      ScreenState=0
   else
      WinGetActiveTitle, Title
      J5=Johnny5.exe %1% -ahk, max
      Run,%J5%, C:\Johnny
      ScreenState=1
return
~Escape::
if ScreenState=1
      WinActivate,%Title%
      WinMaximize,%Title%
      WinActivate,%Title%
      ScreenState=0
else
return
Howard posted yesterday in the Johnny5 WIP thread that he would like to release a test version today.  I'd prefer to wait for that before monkeying with the script anymore.  He suggested previously that the timing settings will need to be "tweaked" for different CPU processor speeds, but I don't know if that will still be the case.
