Author Topic: IPAC-2 sticky key question  (Read 2145 times)
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
« on: August 18, 2005, 11:13:09 am »
The pause key on my CP is acting up.  If I don't press and release it quickly it will register pause-on/pause-off.  So I have to hit it fast to actually register just "pause".  It's like the button is sending two keypresses when I click down/up.  I haven't noticed it on any other keys.  Is this a wiring problem?  I looked over the wiring last night and everything "looks" secure.
Anyone else experience this?
thanks,
stevodevo
Tiger-Heli
    • Tiger-Heli
Re: IPAC-2 sticky key question
« Reply #1 on: August 18, 2005, 12:14:42 pm »
thanks,
stevodevo
Is Pause set as your Shift Key?  If so, the I-PAC will send the action on key release, but that isn't what you are describing. . .
iamnaeth
  • Last login:August 08, 2018, 02:42:59 pm
« Reply #2 on: August 18, 2005, 03:16:29 pm »
I've had the same problem in the past.  It turned out that my microswitches were the problem.  I'm not an expert on any of this but I replaced my switched and haven't had a problem since.  If it turns out to be something else, I'd be interested!
stevodevo
« Reply #3 on: August 18, 2005, 11:43:39 pm »
Hmm..no pause isn't my shift key but I wondered about the microswitch.  I think I've got an extra one.  I'll give that a shot and see what happens!
Thanks guys!
