Author Topic: anyone comment on this pls  (Read 1379 times)
steptoe
  • Last login:February 18, 2012, 09:06:31 pm
« on: August 17, 2005, 10:04:53 pm »
Guys
Im looking at a Gold Tee cab with a Polo 1 or 2 25 inch 15kz monitor in it, is it possible to run it off a video card, might convert to mame.
I think all it needs is the software, that would mean  a PCB right ???????. If its olny a pcb where do you think id find one, and what $ would it be.
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
Re: anyone comment on this pls
« Reply #1 on: August 17, 2005, 10:13:03 pm »
If it is 15 kHz then it needs more than just a VGA connection I imagine.  At least a scheme to keep it from seeing higher freqs.
steptoe
« Reply #2 on: August 17, 2005, 10:31:07 pm »
Trubo
Thanks for your comments, i have no idea about these monitors, i built a cab using 52cm tv, but ive found these golden tee cabs that are complete except software for $240au, which is pretty good, how much trackball on its own, monitor, but anyway. Would this cab take a pcb ? would it take any golf game pcb ?, thanks for your time, but any additional info would be goods.
Thnaks
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #3 on: August 18, 2005, 07:01:34 am »
Yes if its a 15khz monitor you need some way to send a 15khz signal from your computer if you intend using mame e.g. an arcadevga + jpac, according to KLOV the Golden Tee games are JAMMA, meaning that if you get a jamma golf pcb you should be set ( I dont know compatability between controls etc. that golden tee uses, but it would be compatible with your monitor/speakers etc. at least - you would have to check that out for the golf game you are looking at buying)
