Author Topic: What are you using to trim your Happ bezel?  (Read 1439 times)
wallyworld
  • Last login:October 19, 2007, 01:55:54 am
  • Moose outside should've told ya.
« on: August 17, 2005, 07:40:46 pm »
Just curious as to what tool people are using to trim their Happ monitor bezels.
"I think, therefore I drink."
eraserhead
  • Last login:August 18, 2005, 10:18:37 am
Re: What are you using to trim your Happ bezel?
« Reply #1 on: August 17, 2005, 08:53:22 pm »
straight edge, self healing cropping mat (like the kind one would use in the printing biz), ruler, and the sharpest knife you can find :)
make 2-3 passes on the plastic - and then bend the cut area off of the bezel.
works like a champ..
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 18, 2005, 12:08:52 am »
Tin snips.
AlanS17
    • AlanS17
« Reply #3 on: August 18, 2005, 12:37:19 am »
Well I always called them utility knives, but the FAA likes to call them box cutters. Score, bend, snap, presto.
They really score VERY well. They'll even score on a curve (if for some odd reason you wanted to). I recommend holding some sort of metal straight edge in place as you score, though. It'll keep your line straighter.
