Author Topic: 13pin female connectors for 49ways?  (Read 1207 times)
johnx
  • Last login:August 26, 2005, 07:32:46 am
« on: August 17, 2005, 01:03:53 pm »
anyone know where i can get female 13pin connectors like the ones used on midway 49way joysticks?  i was planning on making cables to connect to a wiz49 but dont want to cut the ones on the harness.
thanks
jx
MrSaLTy
  • Last login:August 10, 2025, 05:07:28 pm
  • nabisco reject
Re: 13pin female connectors for 49ways?
« Reply #1 on: August 17, 2005, 01:43:05 pm »
If you have an old floppy cable you can use that and cut it also.  It fits on the 49way sticks.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: August 17, 2005, 07:09:50 pm »
Or buy the rotary adapters that fl0yd sells.  They're inexpensive and he gives you extra connectors and crimpable pins in each kit so you can make a wiring harness for they joystick as well as the rotary adapter.
