Author Topic: Are these good Joysticks?  (Read 1259 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Are these good Joysticks?
« Reply #1 on: August 15, 2005, 11:25:33 pm »
Those are the loud and clicky kind found on "japanese" cabinets.
NO MORE!!
USSEnterprise
    • USS Odyssey
« Reply #2 on: August 15, 2005, 11:31:24 pm »
They appear to be switchable. Are they?
RayB
  • There's my post
    • RayB.com
« Reply #3 on: August 15, 2005, 11:44:13 pm »
Sort of. You have to loosen those screws (looks like there are 2) and then you rotate the restrictor and then re-tighten the screws.
Most of those cheap chinese joysticks come with a restrictor you can move for 2-4-8 way, but always with a screw to loosen/tighten.
NO MORE!!
dogg0
  • Last login:December 14, 2014, 01:18:29 pm
  • ALL? no ALL!!!
« Reply #4 on: August 16, 2005, 09:48:15 am »
I tried to put them in four way mode, but couldn't really figure it out. At least i couldn't get a daimond shape by just rotating the plastic disc. I didn't try very long or actually use them to play yet though.
thou shalt not supress flatulence
-the bassmaster general
Lilwolf
« Reply #5 on: August 16, 2005, 12:20:01 pm »
You can also replace the microswitchs in these with cherries... But then you've removed the price savings.
they probably aren't bad if they are your only joystick.  When you can't compare, you don't notice that they are all that bad.  (btw, ultimates ARE good... until you get a few comps :) )
Goz
  • KOTA
« Reply #6 on: August 16, 2005, 12:23:40 pm »
They look like the coinexpress $2 joys. I have a pair and while they are usuable, they are crap.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #7 on: August 16, 2005, 12:56:59 pm »
I think they stink.  They are extremely loose and cheap feeling.  They do work however.  Can't say I ever had a problem with a missed direction or anything.  I just have a problem with feel and build quality.  If a child ever decided to hang off it, I'm sure that'll mess it up where as a better joy wouldn't.
Next I'll be on fries, and that's when the big money starts rolling in.
Stingray
« Reply #8 on: August 16, 2005, 01:01:05 pm »
You can buy good joysticks from Ponyboy for similar money.
-S
