Author Topic: Wico Sticks  (Read 1405 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
Wico Sticks
« on: August 15, 2005, 05:53:58 pm »
Does Wico make a 4/8 way switchable joystick? I have handles but no bases. Are there any other bases that can accomidate Wico sticks? Either Leaf or microswitch.
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Wico Sticks
« Reply #1 on: August 15, 2005, 06:38:21 pm »
Wico made no switchable sticks in the sense that T-Stick+s or OmniStick Prodigies are switchable.  Wico 8-way sticks also came with a 4-way actuator, so that the stick wouldn't register diagonals.  But you don't get the feel of the 4-way restriction when used this way, and it requires opening your control panel and partially dis-assembling the stick to make the swap, so I don't think that's what you had in mind.
Wico handles will fit Happ Perfect 360 joysticks.  P-360s also come with both 4 and 8 way actuators, and also require opening the panel and partial dis-assembly to change.  Other than that, Wico handles will fit the Chineese knockoff el-fake-o "Wico Style" joystick base, but you wouldn't want to use one of those.  As for official Wico, there are leaf and micro versions of the Wico base out there.  The leafswitch type comes in a dedicated 4-way version as well as the standard 8-way.  I don't know if the microsiwtch type was ever offered in a 4-way or not.  One might be able to mate a 4-way top half from a leafswitch base assembly with a microswitch bottom half to make a 4-way microswitch stick.
NoOne=NBA=
Re: Wico Sticks
« Reply #2 on: August 15, 2005, 11:44:52 pm »
Wico sticks will also fit Supers and Comps.
You just need to dremel an extra groove, just below where the joystick narrows, to put an E-clip.
Kremmit
  • - AHOTW -
Re: Wico Sticks
« Reply #3 on: August 16, 2005, 09:07:27 pm »
Don't they end up just a little bit loose?  The Wico shafts are .5mm smaller, if I remember right.  Or does the spring suspension make the looseness not matter as much as it does in a grommet stick?
NoOne=NBA=
Re: Wico Sticks
« Reply #4 on: August 16, 2005, 09:10:44 pm »
I've never felt any slop in them.
I just stuck them through, and put the E-clip on them.
It never occurred to me that they might not be exactly the right size.
