Author Topic: light guns  (Read 3540 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
light guns
« on: August 13, 2005, 01:02:29 am »
OK I'm officially confused..
I've read through most of the 15 page thread about the Guncom2 drivers and using them in Mame...
I came to the conclusion that, since I use "S" video to my tv, the Guncom2 might not me my best option...since I would be degrading the signal..
So now I'm thinking of getting the new Act Labs gun...is it out yet?
nickbuol
  • Last login:July 22, 2025, 09:55:45 pm
  • 2nd Time Around
Re: light guns
« Reply #1 on: August 13, 2005, 01:46:33 am »
Welcome to the club.  I am still convinced that the GunCon2 stuff, while awesome and making great progress, is not for the average person.  Still too many variables and still too many unsuccessful install attempts to really push me to try it yet.
Not slamming it, I am just as excited as the next guy about that project working, and the people that are taking the time and money to create the code and buy the guns, and test things out should get a big thank you from everyone, I just don't want to spend the time and money to find out that I didn't factor in some aspect and end up with useless hardware or waste too much time to get a few lightgun games working.
Instead, I am putting a Dreamcast into my cabinet.  I already had one with a whole bunch of controllers, including light guns, and the MAME PC will use S-Video, and my Dreamcast will be RCA Composite, so they will both plug in easily to my TV and give me light gun support.  Not as nice as having 1 system, but it will work until the GunCon stuff gets a little more developed.
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
Re: light guns
« Reply #2 on: August 13, 2005, 05:57:20 am »
Why Dreamcast?  It only has like 2 light gun games plus NES emu.  Has some one come up with some way to use DreamCast light guns with a PC?  Your still just useing an RCA signal for your dreamcast so I don't see any advantage signal wise.  With a PS2 even if you don't want to try out the GunCon 2 Drivers with your PC there are still about 16 good light gun games for the system.
aljupy
  • Last login:October 23, 2011, 07:30:06 pm
Re: light guns
« Reply #3 on: August 13, 2005, 06:44:57 am »
<<but it will work until the GunCon stuff gets a little more developed.>> Did you test it before Judge it?
« Last Edit: August 13, 2005, 06:49:45 am by aljupy »
deadmoney5
Re: light guns
« Reply #4 on: August 13, 2005, 08:56:43 am »
wow..didn't realize how wrong I was... :o
but I still have an "S" video out from my card to the tv....Are there any guns that use "S" video?
Lilwolf
Re: light guns
« Reply #5 on: August 13, 2005, 09:05:41 am »
all the guncons do.  But you have to build a circuit for it.  If I remember correctly (I didn't build one... I'm still waiting on the vga release) the easiest way is if you have a composite out in the same video card.  Otherwise it takes a little work.
nickbuol
  • 2nd Time Around
Re: light guns
« Reply #6 on: August 13, 2005, 09:56:30 am »
For the DC I have some import gun games too, so I have a few choices.
As for development, as mentioned by a lot of people, heck even someone asked a few weeks ago for a GunCon2 FAQ or "How To" but the thread quickly faded away.
Then, if you want S-Video, you need a circuit built to work?  I thought that you could hack an S-Video cable to get the GunCon RCA cable to tie into that.  Maybe that has changed, don't know.  I've spend a few hours trying to sort through everything, and still don't feel like I am 100% condifent in how to set it all up.
Again, I love the project, I WILL participate in the GunCon2 route, but if I need a circuit built, I sure wouldn't know how to do it, and then with calibration issues, different guns working with smoked glass (which I have) and so forth, I'm just not ready.  Others are, but then again I am still just trying to get my cabinet done first, then I will revisit it.  Oh, and the Dreamcast is being used for much more than a few light gun games.  My kids are big into DDR, so that, plus my other 200+ Dreamcast games need a new home since my wife says that it can no longer sit in the living room.
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
Re: light guns
« Reply #7 on: August 13, 2005, 10:49:27 am »
Most if not all the guncon2 guns use composite (rca style) connection.  I have mine connected to the RCA out on my MSI Geforce 4200 Ti and I have my TV connected to the svideo out on my geforce 4200 Ti so no special cables it just works!
I have 2 guns hooked up, I have tried both the WinGun drivers and smogs Guncon driver both have advantages and disadvantages but both work very well and are very easy to install and calibrate.
Bottom line if you have a TV (no matter what type of connection) what have you got to lose if you spend $20 on a guncon2 gun and give it a go.  OR you could spend $100 on Actlabs... Your choice.   Even if you don't have a video card that has both the svideo and the composite (1 rca type cable) or you have component (3 rca type cables), you can hack an svideo cable to Y out to composite signal for the gun relatively easy and it works...
I dunno for $20 I think it's worth the gamble. And they DO work. One of the 2 drivers WILL work with whatever guncon you buy.
deadmoney5
Re: light guns
« Reply #8 on: August 13, 2005, 11:21:53 am »
Holy Schnikies...
I think I got lucky...
I assume the yellow input on my videocard next to the S-video is the video out for rca composite?
I didn't know I had both!!
So all I have to do is get the gun..plug the USB into computer, plug yellow rca into videocard...install one of the drivers....and I'm ready to go?
deadmoney5
Sensei
  • Last login:May 03, 2008, 11:30:58 am
  • Take this pebble from my hand.
Re: light guns
« Reply #10 on: August 13, 2005, 12:15:46 pm »
-ActLabs: Callibration it is very easy. But do not expect the better results. When you reboot System, you loose callibration.
-Wingun: It has 2 options, Autocallibration (Act Labs style), or manually callibrate (Recomended for experienced players and for Excepcionally accurate results). You can Save your own callibration for every profile you that make with this aplication. You
vibez
  • Last login:February 09, 2011, 08:33:20 am
Re: light guns
« Reply #11 on: August 13, 2005, 12:49:59 pm »
anybody have this gun?
http://cgi.ebay.com/PlayStation-Guncon-Sexxxy-Gun-SEALED-LQQK_W0QQitemZ8211541606QQcategoryZ21193QQrdZ1QQcmdZViewItem
That is only guncon1 You need guncon2. Funny, but that gun looks identical to the new actlabs guns!
Another point worth mentioning is that Smog's driver only works on XP SP2. I'm not sure about Acorns driver
Acorn
  • Last login:February 12, 2006, 03:04:58 pm
  • Lightguns!
    • WinGun Driver
Re: light guns
« Reply #12 on: August 13, 2005, 07:22:40 pm »
My newest will work in Win2k/XP (any SP). My older ones (0.1B and 0.2B) will work in 98, but require a seperate package.
When looking for guns, be sure they are guncon2 compatible (have the USB plug)!
Get WinGun (Guncon 2 PC USB Driver) at http://www.guncon2driver.com
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: light guns
« Reply #13 on: August 13, 2005, 08:21:14 pm »
does it matter what gun you use if you have PAL or NTSC?
DannyH
  • Last login:August 17, 2009, 07:27:28 am
Re: light guns
« Reply #14 on: August 13, 2005, 09:11:08 pm »
I bought an old PC Mag light gun for $10AUD the other week and plugged it in. This thing works great, However my monitor is almost flat so I may have to re-sell it. This was a great option for me!
steptoe
  • Last login:February 18, 2012, 09:06:31 pm
Re: light guns
« Reply #15 on: August 14, 2005, 11:09:02 pm »
DannyH
Re: light guns
« Reply #16 on: August 14, 2005, 11:24:15 pm »
My personal opinons of byquick aside I think that looks pretty good. I have had a bad experience buying from them but they are pretty quick with delivery and service
steptoe
Re: light guns
« Reply #17 on: August 14, 2005, 11:34:18 pm »
steptoe
Re: light guns
« Reply #18 on: August 14, 2005, 11:37:31 pm »
