Author Topic: monitor shelf supports  (Read 1101 times)
mlcampbe
  • Last login:December 08, 2022, 10:54:49 am
« on: August 11, 2005, 12:34:20 pm »
I've lucked upon a 21" monitor for my cabinet and have a quesiton about how to best install/support it. The monitor weighs approx 80 pounds. I don't want to put screws from the outside of the cabinet through the 3/4" MDF into the shelf mounting boards but I don't see how else to properly support the weight of the monitor.
If I put in 10-15 screws throgh the 2x4 that holds the shelf into each side of the cabinet will that be enough?
What works best?
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: monitor shelf supports
« Reply #1 on: August 11, 2005, 07:58:09 pm »
That and some builders glue between the 2 pieces of "wood"
