Author Topic: Teaser?  (Read 13445 times)
quarterback
Re: Teaser?
« Reply #40 on: August 13, 2005, 09:55:12 pm »
Yes, but how many of us figured it out manually, and how many used some online tool? :)
I did it letter by letter, although most of the words only required the first letter and knowing what "20" is to figure out what the word was.
-- Chad Tower
MrTroy
  • Last login:August 14, 2012, 12:13:12 am
  • Working on 4 projects
    • TDP.com
Re: Teaser?
« Reply #41 on: August 13, 2005, 10:26:36 pm »
Ugh... 19 days later would be better. Then it's my Birthday.... :)
Troyd = Loser. ;D
Lounge Room Arcade finished 12/08/2005
AlanS17
    • AlanS17
Re: Teaser?
« Reply #42 on: August 14, 2005, 01:25:49 am »
I actually broke it down into columns in Excel and did character conversions from there. So maybe it's halfway cheating, but it was still pretty darn manual.
Bones
  • [Moderator]
Re: Teaser?
« Reply #43 on: August 14, 2005, 05:22:20 pm »
I ran it through my TI994/a but ran out of memory.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: Teaser?
« Reply #44 on: August 15, 2005, 01:31:25 pm »
Poonga keeps saying that the hexi-yoke-date-thingy might not have been the teaser at all, so are we supposed to continue searching around the forums in the hopes that we find the elusive teaser??
Well, am i right?  Saint doesn't confirm that it is the teaser, just hints that it is :)
I used calc.exe.  I know the decimals of all alpha characters of the "american standard code for information interchange"  by heart.  It's a matter of using calc to convert the hex to decimal then for me :)  My many years of programming in BASIC using chr...
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
Re: Teaser?
« Reply #45 on: August 15, 2005, 03:19:45 pm »
Reminds me of hacking Atari 800 games back in the 80's.  :-X
Bringing to life a child's imagination.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:November 22, 2025, 12:26:51 pm
Re: Teaser?
« Reply #46 on: August 15, 2005, 03:49:06 pm »
Heh, I used calc.exe also. I didn't trust my memory of the ascii codes, so I used the ALT-num-pad trick...
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
saint
Re: Teaser?
« Reply #47 on: August 15, 2005, 03:49:19 pm »
OH, and yeah, that was the teaser :)
--- John St.Clair
     Project Arcade 2!
SirPoonga
  • Puck'em Up
Re: Teaser?
« Reply #48 on: August 15, 2005, 04:05:11 pm »
Good :)
Heh.  I just remember key demical values and add from there mostly.  But I like that technique, less thinking involved.
space=32
0=48
A=65
E=69
M=77
S=83
Z=90
a=97
e=101
m=109
s=115
z=122
Odd ones I know off hand, i.e. all the ones important in old school text parsing and dos programming.
BEL=7
TAB=9
NL = 10
CR=13
esc=27
Heh, I think it is safe to give away the code now.  Between saint's and my reply you should  have the tools to figure it out.  ...and AlanS17 spelling out the acronym :)
Put "american standard code for information interchange" into google and click I'm Feeling Lucky :)
« Last Edit: August 15, 2005, 04:18:56 pm by SirPoonga »
cdbrown
  • Bowowow
Re: Teaser?
« Reply #49 on: August 16, 2005, 01:58:10 am »
I wouldn't have a clue how to work it out - so what does it say?
SirPoonga
  • Puck'em Up
Re: Teaser?
« Reply #50 on: August 16, 2005, 10:03:38 am »
Understandable, it is using the "american standard code for information interchange", not the australian one ;)
AlanS17
    • AlanS17
Re: Teaser?
« Reply #51 on: August 16, 2005, 10:32:01 am »
Know where you're going doesn't matter if you still don't know how to get there. How many people can count in hex? I figured that would be the stumper for most people and that mentioning ASCII wouldn't be a big deal.
SirPoonga
  • Puck'em Up
Re: Teaser?
« Reply #52 on: August 16, 2005, 10:39:01 am »
True, but you google the thing and you get a lookup table, no need to know how to count in hex then, just find the match.
whammoed
  • Last login:Yesterday at 10:05:01 pm
  • Crack don't smoke itself
    • NiceMite
Re: Teaser?
« Reply #53 on: August 16, 2005, 10:51:00 am »
I used my Little Orphan Annie decoder pin.  It told me the release date then it told me to drink my Ovaltine! ;)
quarterback
Re: Teaser?
« Reply #54 on: August 16, 2005, 11:42:30 am »
I won't tell you what it says, but I'll tell you how to figure it out without beeking a geek! :)
Here's the code you want to crack:
Code: [Select]
54686520466c6967687420596f6b652052656c65
61736520646174652069732053657074656d6265
7220313074682c2032303035
Here's an exed-out version of the sentence from jerryjanis' post:
Code: [Select]
xxx xxxxxx xxxx xxxxxxx xxxx xx xxxxxxxxx xxxx, xxxx
It's simple substitution.  The first thing I figured out was that "20" = "space" which is pretty obvious from comparing the code to the exed-out sentence.
The other bit of information you have to work with is that the message will tell you the flight yoke release date.   With those 4 things, you should be able to crack the code in no time.... at least the vast majority of it and then one important specific character can be easily deduced.
Have fun! :)
-- Chad Tower
SirPoonga
  • Puck'em Up
Re: Teaser?
« Reply #55 on: August 16, 2005, 12:31:57 pm »
Right, because ", xxxx" would have to be ", 2005".
AlanS17
    • AlanS17
Re: Teaser?
« Reply #56 on: August 16, 2005, 01:51:06 pm »
Well gee, I don't know how much I can say without giving it away?  :P
It's one long hex string, but every ASCII character is 2 hex numbers in length. That's not really giving anything away, though. You could figure that out by counting everything between spaces.
The hardest part is converting the hex to decimal (unless you seriously cheat and use a hex -> ASCII code table).
