Author Topic: CP thickness (MDF)  (Read 4842 times)
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
CP thickness (MDF)
« on: December 31, 2002, 10:40:15 am »
What is the standard thickness of a control panel?
I am currently thinking 3/4" MDF.  I have used MDF to build speaker boxes before.. and it's quite sturdy..
if I add 1/8-1/4" of plexi/lexan to that.. will it be too thick?
Surgeville
  • Last login:October 18, 2025, 12:30:21 pm
  • Always so close, yet so far!
Re:CP thickness (MDF)
« Reply #1 on: December 31, 2002, 10:48:11 am »
I used 3/4" mdf for the cabinet itself, but went with 5/8" for control panel, because I reasoned that when I put on the 1/8" plexi on top, it would be just right.
Now that I have one of the boxes done, I don't think that extra 1/8" would make a difference, and I think I might make some of the control panels without the plexi at all.
JoeB
  • Last login:November 24, 2025, 05:49:35 pm
  • NES Fanatic
« Reply #2 on: December 31, 2002, 11:11:52 am »
I actually got a 3/4 MDF myself.. 1/8 on an inch extra will not be noticed.  I know this because I'm actually restoring an old cabinet that was abused into a MAME one, and it had a 3/4 plywood top with 1/8 plexi and it looked fine.
The problem I came across is that I noticed that the actual 8-way controllers were recesed into the wood, and was wondering how one can do it at home, or if it's required at all!?
i.e. The original board is 3/4 inch, but where the joystick is installed, the bottom had a square piece cut down to about 1/4 to 1/2 inch deep where the joystick went in (from underneath).  How does one do that?! and is it required??
JoeB
Driath
  • Last login:May 25, 2005, 04:30:22 pm
  • I'm a p
« Reply #3 on: December 31, 2002, 11:16:36 am »
I think I'm a loner on this one, but I used 1/2 MDF with 1/8 Plexi.. then when using 1/2 Screws, it grabs a very nice amount of the wood w/o going through the back. I don't personally see the advantage of going 3/4 as mine is sturdy enough and sure as heck already heavy enough (When I build the cab / another cp I'll probably go Ultralight MDF to save 30% the weight).
PS: I just posted my first control panel pictures here
http://bellsouthpwp.net/D/r/driath/
Spectrum
  • Last login:January 09, 2014, 09:46:11 pm
« Reply #4 on: December 31, 2002, 01:53:34 pm »
JoeB to "hollow out" a mounting hole for the joysticks you need to use a router.  Also need a router for slotting T-molding.
Driath  good looking CP you got going on :)  gonna cover it with some pretty artwork or keep the pink look?
Driath
  • I'm a p
« Reply #5 on: December 31, 2002, 03:01:55 pm »
Thanks Spectrum... I'm actually designing the art now... I am going to print it this weekend at Kinko's... i'll post a thread up when it's done for some critique... the pink is jsut the plexi protective film so i don't scratch it while still designing everything hehe
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #6 on: January 02, 2003, 01:19:44 am »
I'm redoing one of my control panels that is already exactly 3/4.  I'm redoing it because I want to add artwork and a plexi top.  Happ Supers are made for 3/4.  Any thicker (even 1/8 more) will make the stick to low, so you would either have to route out the underside, and/or maybe increase the diameter of the hole.
I'm going with 5/8 thick board with 1/8 plexi.
Silverwind
« Reply #7 on: January 02, 2003, 12:28:10 pm »
I'm thinking about going 3/4" and then routing a square to mount the happ super..
I figure might as well make the CP thick.. since everyone will be leaning on it etc...
maybe on the top of my CP i'll route some cup holders in :P
hehe j/k
