Author Topic: Grommets Grommets where are the Grommets?  (Read 1628 times)
flyguy1821
  • Last login:October 23, 2022, 11:06:19 pm
« on: August 06, 2005, 11:33:06 pm »
Anyone know where I can find a grommet for 3/4 inch MDF that will accept an RCA plug? I have found a few that will fit 3/4 size but they are all like an inch hole or such.  Much to big to an RCA or component plug.
AlanS17
    • AlanS17
Re: Grommets Grommets where are the Grommets?
« Reply #1 on: August 07, 2005, 01:51:47 am »
Can you install some sort of 1/4" shim on the inside?
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« Reply #2 on: August 07, 2005, 02:22:44 am »
Try these.  You see them on fancy computer desks.  You'll still need to have some clamp for the cable on the inside.
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
flyguy1821
« Reply #3 on: August 07, 2005, 11:11:59 am »
here is a link that is close to what I want but like I said difficult finding a grommet that will fit 3/4 mdf and not have a huge opening.
http://www.astrotex.com/grommet.htm
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« Reply #4 on: August 07, 2005, 11:13:58 am »
when my daughter throws up she says she "grommited"
sorry.... :-[
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
AlanS17
    • AlanS17
« Reply #5 on: August 07, 2005, 12:13:59 pm »
Get a grommet to fit 1/8". Cut a larger hole in your opening. Cut a hole the size you're looking for into a metal plate. Attach the metal plate to the hole. Tada.
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #6 on: August 07, 2005, 01:08:31 pm »
I am having the same problem. I think I'm going to get one of the grommets designed for metal panels, cut it in half, and epoxy one half to each side of the MDF panel. I'm using a rubber-coated cable clamp on the inside to prevent tension on the outlet box inside. (My cabinet's power comes from a heavy gauge line cord to an outlet box on the interior. A UPS is plugged into the outlet box, then everything inside -- computer, USB hubs, monitor, etc. -- is plugged into the UPS. Well, actually into a Bits Limited SmartStrip which is plugged into the UPS.)
-- Chris
Underway: Joey's Arcade
