Author Topic: Control Panel Wire-->24 g Speaker Wire  (Read 1218 times)
MAME nut
  • Last login:March 18, 2024, 12:33:01 am
« on: August 05, 2005, 02:00:31 pm »
Just curious if 24 gauge speaker wire (stranded) will work to wire up Control Panel switches??  I have a bunch that's collecting dust....
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
Re: Control Panel Wire-->24 g Speaker Wire
« Reply #1 on: August 06, 2005, 01:45:46 am »
NO!
It will SURELY catch fire from all the current going through the arcade buttons / joysticks.
You need at least 14 gauge wire.  Maybe 12 to be safe for the grounds.
The above is a joke.  Your wire should be fine.
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« Reply #2 on: August 06, 2005, 03:31:30 am »
I thought you were serious at first....12 is way, way too big, I have 12 gauge wire  powering the 12 inch subs in the trunk of my car, I am using 16 gauge, 16 to 18 would be good.
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: August 06, 2005, 11:25:32 am »
24 is fine.  A lot of the iterfaces are using hacked IDE cables which are 28-32 gauges (lots thinner).
