Author Topic: rewire yoke....series to parallel  (Read 1295 times)
GalaxyForce
  • Last login:January 30, 2006, 01:46:46 pm
« on: July 27, 2005, 07:35:48 am »
its on a Nanao MS8-26SE,  the vertical resistance is to high to go with a 8liners chassis,  the original chassis is crap.  so if i wire the yoke in parallel it gives me 9.5 ohms instead of the 37ohms.   does anyone know if this is ok to do, or will it not work properly?
thanks
Ken Layton
  • Guru
  • Technician
Re: rewire yoke....series to parallel
« Reply #1 on: July 27, 2005, 12:33:20 pm »
8liners sells a high impedance version of the chassis. No need to dink around with rewiring a yoke.
