Author Topic: Video Card Advice Needed  (Read 1144 times)
bishmasterb
  • Last login:March 23, 2014, 09:27:47 pm
  • Pressing the limits of my wife's patience...
    • Bishopzone
« on: July 27, 2005, 02:20:00 am »
I have a Dell Optiplex GX270 that I am looking to put a video card with component video output into.
According to the online system specs from Dell, I believe it has an AGP slot. Opening up the case there is a green slot offset from the rear of the system board further than the PCI slot. I have no idea what speed it is though (1x, 2x, 4x, etc. ?).
The case only accepts the half-height expansion cards (about 2" tall).
Can anyone recommend a half-height AGP card that will perform well for MAME and other emulators. I'm not interested in playing PC games on it right now, so I don't need any 3d capabilities.
Thanks in advance.
-bish
"We have just enough religion to make us hate, but not enough to make us love one another." -Jonathan Swift
bishmasterb
    • Bishopzone
Re: Video Card Advice Needed
« Reply #1 on: July 29, 2005, 12:03:30 am »
OK, I found a card and hooked it up and it produces great video quality through an S-Video port.
However, there's a problem. If I leave the TV on for a while (anywhere from a few seconds to 10 minutes or so) the video will eventually start blinking back and forth between a color and b&w image, slowly at first, and then rapidly. Once this starts, the only way to stop it is to turn the TV off and back on.
I've tried the three different S-Video inputs on this TV and they all have the same problem. I don't have another TV with S-Video inputs to try however.
Interestingly, if I go into the TV's menu mode (which displays the video signal in a smaller window so you can see the input image and the menus) the problem completely disappears and the video in the window looks normal (although smaller of course because it's in a window).
Any ideas?
Skadar
  • Last login:August 07, 2017, 02:20:01 pm
  • I love my new Corsair keyboard: RRRrrrrrr!!!!
    • Ooine.com
« Reply #2 on: September 02, 2005, 01:12:19 pm »
Which card did you end up using?
