Author Topic: Standard Op. Wolf Gun on Mame?  (Read 1525 times)
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« on: July 26, 2005, 10:21:56 am »
Hello,
Is there a way to rig a standard Op. Wolf machine gun up to work with Mame?  I have the D9200 monitor if it makes a difference?  Thanks.
Re: Standard Op. Wolf Gun on Mame?
« Reply #1 on: July 26, 2005, 11:37:16 am »
I *think* Op. Wolf had 2 different possible types of gun: optical and positional.  If it is the positional type, then you can interface it like an analog joystick as it will use pots.  If it is optical, you can't interface it atm.
The above statement could be wrong, it might have just come with positional guns.  Either way, positional guns should work (people here have done it), although it might be hard to calibrate the gun's physical position with the on-screen target.
Also, do a search on this board, the subject has come up numerous times ;)
wintermute
  • Last login:December 01, 2006, 09:04:25 am
  • Whip the thugee guards.
« Reply #2 on: July 26, 2005, 02:44:24 pm »
I have an Operation Wolf Cabinet and it's definitely a positional gun.  I don't know if other models had optical.  Or maybe operation thunderbolt was optical?
wm
