December 03, 2025, 12:24:51 am
So I don't have easy access to a solder iron to remove some globs left over on a few buttons Ive stripped from a CP.Is solder relatively soft enough that I can take a dremel with a grinding stone and shave it down so I can get quick conencts over the terminals? Basically when I pulled the buttons I just clipped the wire as clsoe to the terminals as I could. I don't really care to buy a soldering setup since I'm using a Ipac/Optipac and spade quick connects on everything, unless I can find one for < $5.
