Author Topic: How do I tell what ver. of MameWah I have?  (Read 1917 times)
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« on: July 19, 2005, 09:07:05 am »
Anyone?
Re: How do I tell what ver. of MameWah I have?
« Reply #1 on: July 19, 2005, 10:23:59 am »
Older versions (0.97 and before, IIRC) have an 'About' option in the main menu which will tell you the version.
New versions should say the version no. in the \ini\*.ini files.
You can also hover over the exe file in explorer, and it should display the version no., although in Microsofts numbering format (which I kindof ignore) - eg it might say v1.6.1.0 or something which I call v1.61.
Confused!?  ;D
electricd
  • I'm not a llama!
« Reply #2 on: July 19, 2005, 02:26:39 pm »
Ok I have version 1.5.0.0 acording to the hover-over trick.  My question is, I would like to now update to the latest version.  How should I do this, and what pitfalls should I watch out for?  Thanks in advance!!!
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« Reply #3 on: July 19, 2005, 05:49:56 pm »
You can download the latest mamewah1.61 from mameworld.net
electricd
  • I'm not a llama!
« Reply #4 on: July 19, 2005, 05:51:50 pm »
Yea I know where to get it, I just don't know if the upgrade will go smoothly...can anyone tell me?
« Reply #5 on: July 20, 2005, 04:43:31 am »
Well it's been a while...I *think* for the most part you should be OK, but then again you will likely have to enter the new 'commandline_format' settings for each emulator (you don't have this setting in v1.5 right?)
Best thing to do is download v1.61, and read the \docs\ini.txt file - have a look what's changed.  I think the part I mentioned above will be the only major thing.  John Crouse's website has examples for millions (nearly) of emulators if you need a guide - a link is at the 'help' page of my site.
electricd
  • I'm not a llama!
« Reply #6 on: July 20, 2005, 09:07:24 am »
Ok thanks.  I like to try and keep updated, so I will likely do this upgrade this weekend.  Thanks again.
electricd
  • I'm not a llama!
« Reply #7 on: July 20, 2005, 09:17:31 am »
Wow..commandline_format looks confusing to me (guess I should have stayed on top of this stuff!).  Where is a link to Crouse's site?  Thanks!
« Reply #8 on: July 20, 2005, 11:19:07 am »
