Author Topic: VCR to D9200  (Read 1926 times)
paigeoliver
  • Awesome face!
VCR to D9200
« on: July 19, 2005, 04:32:51 am »
Is there a way to hook a VCR or other AV equipment up to a Wells Gardner D9200 monitor?
paigeoliver
  • Awesome face!
Re: VCR to D9200
« Reply #1 on: July 19, 2005, 04:35:43 am »
ANd to be more specific, is there a way to do it that doesn't involve hooking the VCR up to the computer and then running that to the monitor.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: VCR to D9200
« Reply #2 on: July 19, 2005, 09:33:47 am »
http://www.aver.com/products/tvtuner_AVerTV_box5.shtml#2
You might want to give their tech support a ring and make sure you can set it up for
640x480.
Later,
dabone
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
Re: VCR to D9200
« Reply #3 on: July 19, 2005, 04:00:06 pm »
I have an ATI TV wonder PCI.  It is a stand-alone card and not the all in wonder.
It has a video input and I have plugged in devices such as Playstation and a DVD player.  On my PC I can have it in a window or full screen.  This would be the easiest way to do it, through your PC with a tv tuner of some sort.
A straight through hook-up? I'm not sure about that one.
whammoed
  • Last login:February 17, 2026, 12:42:21 pm
  • Crack don't smoke itself
    • NiceMite
Re: VCR to D9200
« Reply #4 on: July 19, 2005, 04:16:10 pm »
Why don't you want to do it that way?  Won't the d9200 normally be hooked up to a pc anyway?
dabone
  • Time to work...
Re: VCR to D9200
« Reply #5 on: July 19, 2005, 04:54:10 pm »
I'd imagine it's because he would like to be able to watch tv with having to run the
computer.
(It's also a easy way of hooking up a xbox, ps2, etc to the 9200)
Later,
dabone
paigeoliver
  • Awesome face!
Re: VCR to D9200
« Reply #6 on: July 19, 2005, 05:34:07 pm »
computer.
Later,
dabone
EXACTLY.
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: VCR to D9200
« Reply #7 on: July 23, 2005, 12:04:02 am »
The problem with using a PCI or USB tuner is there is a delay in the display. We were seeing a 2-3 field delay when comparing a PC tv tuner with a TV connected to the same source. This is unacceptable for gaming.
quadmasta
  • Last login:May 18, 2022, 03:23:00 pm
    • Approximate Arcades
Re: VCR to D9200
« Reply #8 on: July 23, 2005, 12:07:39 am »
See if you can find a converter that converts NTFS to PAL.  I'm pretty sure PAL will display on the monitor through SCART.
Silverwind
Re: VCR to D9200
« Reply #9 on: July 23, 2005, 11:09:01 am »
I have played PS1 through my tv tuner and it ran great.  For some reason cable TV feeds have a split second delay, and I'm not sure why.  The quality is still good IE no stuttering but it is a split second behind a regular TV.
http://www.starkelectronic.com/vga300.htm
that sort of gives you an idea of a converter.. it is more expensive than a simple gender changer...
