Author Topic: Mame, screen alignment, sound jitter  (Read 1770 times)
DannyH
  • Last login:August 17, 2009, 07:27:28 am
« on: July 18, 2005, 10:20:40 pm »
Hi,
I use GameEx and Mame32 with a couple of other emus as well for consoles etc.
Anyways sometimes when loading a game the screen pushes tothe left hand side and doesnt align in the center, which means at times part of the game is cut off, any ideas?
Also in some games the sound is jittery and skips or repeats itself.
My machine is
PIII 500Mhz, 500MB Ram, 40GB fireball HD, 16MB tnt 2
Any ideas?
cheers
Re: Mame, screen alignment, sound jitter
« Reply #1 on: July 19, 2005, 05:14:52 am »
Adjust your monitor to fix the screen centering...
Get a new pc to fix your sound problem!
Sorry, what I mean is your PC is probably having trouble coping.  Lower the sound sample rate and disable anything like triple buffer, vsync etc. that might improve performance.
amerish
  • Last login:June 20, 2015, 11:01:33 am
  • Why build 1 when you can build 2 at twice the cost
    • You Saw It On TV
« Reply #2 on: July 19, 2005, 01:44:29 pm »
screen shifting to the right -I had the same problem with mame32 and windows xp
Right mouse click on the game and select properties.  Uncheck Direct 3D (Direct 3d tab) and uncheck Use direct draw (advanced tab)
« Reply #3 on: July 20, 2005, 04:40:23 am »
You should almost never turn off DirectDraw...I would not agree with that recommendation.
