Author Topic: I need a Vertical Shelf mount  (Read 1329 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: July 14, 2005, 03:12:18 pm »
My new aquisition (Juno First) used a vertical shelf-mount monitor. I hear they are rare. Is it even possible to buy a new one in this configuration? I'm just trying to avoid hacking in new rails.
NO MORE!!
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: I need a Vertical Shelf mount
« Reply #1 on: July 14, 2005, 04:08:17 pm »
Nope, they don't make 'em anymore. :-(  We do have a monitor that may work for you.  We have a custom frame we use on our Nintendo Replacement monitors.  Take a look-see here and let me know.  We can mount a 19" Happ monitor in them, but I'll have to work out a price if you need one.  I believe I can do one for about $250.  The shelf on it is as wide as a standard shelf mount monitor, but the mounting holes use the Nintendo bolt pattern.
http://www.mikesarcade.com/cgi-bin/store.pl?sku=MONITORN
Another option, is to just transplant a new monitor into your existing frame.  I've done this before and it works fine.
Best,
 - Mike -
RayB
  • There's my post
    • RayB.com
« Reply #2 on: July 14, 2005, 10:39:10 pm »
NO MORE!!
MonitorGuru
  • Last login:October 05, 2005, 11:29:43 pm
« Reply #3 on: July 14, 2005, 11:30:52 pm »
Just build a frame out of particle board, MDF or plywood. Use the center cutout for the tube , cut diagonally and use as the sides to support the chassis.
I've done this a couple times and with large bolts and washers it holds fine.
