Author Topic: asteroids cab dimensions  (Read 9883 times)
danny_galaga
  • Last login:Yesterday at 07:29:41 pm
    • dans cocktail lounge
« on: July 14, 2005, 02:43:35 am »
anyone have the dimensions for an upright asteroids cab? i cant seem to find anything here and jakobud doesnt list it. the main thing at the moment though is to get upright dimensions and control panel layout.thanks in advance!!
« Last Edit: August 01, 2005, 09:38:15 pm by danny_galaga »
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
Re: asteroids cab dimensions
« Reply #1 on: July 14, 2005, 08:13:37 am »
Funny, I was sure Jakobud had Asteroids plans. I don't know where else I would have seen them.
Asteroids does have a cocktail version, it uses the same PCB as the upright version but is wired slightly differently (when certain pins on the connector are closed the PCB knows to flip the screen, open one players controls and close the other players controls; thats why the PCB only has inputs for one player)
I've been waiting for an emulator that emulates cocktail Asteroids, but I don't think its ever going to happen  :'(
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: July 14, 2005, 10:05:03 am »
JoyMonkey
    • JoyMonkey.com
« Reply #3 on: July 14, 2005, 10:48:29 am »
Right. So there's seperate grounds on the harness for Player1 and Player2.
How do you think this could be emulated in Mame? Should there be a seperate rom set or a fake dip-switch added?
Every few months I bug one of the Mame devs about adding cocktail support, and they show a little interest then give up. It'd be nice to see it happen some day.
SirPoonga
  • Puck'em Up
« Reply #4 on: July 14, 2005, 10:57:40 am »
Well, a fake dipswitch probably could be added, after all all you are fdoing is shorting pins 7 and 19 on the harness, IE put a switch on those pins :)  I'll email the mamedevs too.
danny_galaga
« Reply #5 on: July 14, 2005, 09:16:58 pm »
cool. i was referring to the mame version. would be nice to able to play it properly on my cocktail cab one day!
so does anyone have the dimensions for the upright? jakobud definitely doesnt list it...
danny_galaga
« Reply #6 on: July 17, 2005, 11:33:17 pm »
nobody?
danny_galaga
« Reply #7 on: August 01, 2005, 09:40:51 pm »
bump. just in case theres a new guy on here who just so happens to have the dimensions...
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« Reply #8 on: August 02, 2005, 04:51:36 pm »
I asked Jakobud about this a while ago. He didn't have the dimensions at that time but thought he might be able to get them from a local machine.
Have you asked him, or just looked at his web site?
danny_galaga
« Reply #9 on: August 02, 2005, 09:19:51 pm »
i just looked at his site as i guess that once he has em, hell post em...
danny_galaga
« Reply #10 on: October 17, 2005, 06:37:05 am »
time for my bi-monthly bump! still no one with dimensions?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #11 on: October 17, 2005, 02:45:50 pm »
PM Sent
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
AC.
  • Last login:January 21, 2015, 03:55:07 pm
    • MAME console
« Reply #12 on: October 17, 2005, 05:06:44 pm »
You still need dimensions?  My cab:
http://www.carnine.net/arcade/
Was a converted Asteroids cab and I'll measure it if you still need . . . ?
danny_galaga
« Reply #13 on: October 19, 2005, 06:54:21 am »
thanks for the replies guys! cheffo is onto it! so hopefully ill be able to start a new project this year (",)
rayt13
  • Last login:January 26, 2014, 06:36:10 pm
« Reply #14 on: February 09, 2006, 10:59:12 pm »
Any dimensions yet?
CheffoJeffo
« Reply #15 on: February 09, 2006, 11:01:55 pm »
Odd ... I pulled out the MJ beside the Asteroids today and said to myself "hmmm ... I still owe Danny Galaga those Asteroids dimensions" ...
I'll try to get to it soon.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
danny_galaga
« Reply #16 on: March 23, 2006, 07:05:56 am »
ok, well ascar9 came up with many of the dimensions of his cab. ive drawn them up so its easier to follow. the drawing was done in paint, so its not to scale! be warned. the dimensions are as close as i could get. obviously A, B, C, E, G, H i dont have clear measurements of. these could probably be extrapolated in a drawing program.
im amazed there arent full dimensions out there. this is quite a classic cab. that and space invaders. anyway, here is what i can contribute (with much help from ascar). cheffo, if you can, can you compare to yours to see how close they are? i noticed two different dimensions in two different flyers for instance so who knows how many marks of cab atari made...
edit: i also don't have a dimension for the radiused corners, and so they appear angular in the drawing. i would need to have a cab to hazard a guess. the easiest way to measure them would be to use a few objects (like coins, glass tumblers, aerosol cans, etc) of different diameters to see which most closely fits the actual radius...
« Last Edit: March 24, 2006, 04:25:22 am by danny_galaga »
CheffoJeffo
« Reply #17 on: March 24, 2006, 07:28:47 am »
Just bumping his back to the top to remind myself ... once I drop the kids off and clear the morning workload, I'll drag her out and fill in the measurements and get the radial nmbers.
My apologies for letting this one slide so long. :(
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
danny_galaga
« Reply #18 on: April 05, 2006, 04:38:45 am »
Cheers
and you STILL forgot, didn't you?  ;)
CheffoJeffo
« Reply #19 on: April 05, 2006, 03:22:30 pm »
Yep ....  :-\
OK ... here is what we have so far ...
A is 4.5"
B is 9.5"
C is 23"
D is 9.5", with the caveat that is measured on the side panel. If measured front-on, it is 8.5" (excluding marquee retainer) since the top and bottom of the marquee are each recessed by 0.5". You will notice that this doesn't jive with th existing measurements, so I remeasured using theoretical squared corners and I get 38.75 instead of 39.5 and 24.25 instead of 24 for the heights of floor to CP and CP to marquee.
E is 25.25"
With respect to F,G,H, what is the frame of reference for measuring ? There is the plexi bezel, which has a large, easy-to-measure viewable area and the inner folded cardboard bezel (shroud) that surrounds the screen and is tougher to measure.
On the other hand, if you are going to build using a standard black bezel and 19" monitor, you can simply center within the screen area as anything else would look odd.
What you may want to do is grab Zakk's Asteroids model and scale to a height of 72.5" as that is a prety solid measurement.
http://arcarc.xmission.com
Cheers & Apologies.
Working: Not Enough
Projects: Too Many
Progress: None
