Author Topic: Glue guns for DC pads  (Read 1985 times)
Franco
« on: July 11, 2005, 07:40:53 pm »
Ive been looking at DC pad hacks and it seems the norm to use a glue gun to neatly hold the wires in place. I have been looking at glue guns on ebay and they seem to range from about 5w to 80w. I was just wondering what kind of rating people have used in the past. I want something that will keep the wires in place but will not damage the PCB.
pmc
  • Last login:Today at 12:21:50 pm
    • website
Re: Glue guns for DC pads
« Reply #1 on: July 11, 2005, 08:40:56 pm »
I have a tiny weener craftsman model (no trigger, just push the glue stick with your thumb). Honestly, it works fine. If you don't need it for other stuff, you can probably get away with the most inexpensive (name brand) model that you can find. I use hot-glue enough that I'll likely upgrade to a bigger trigger-model version at some point.
Higher wattage probably means faster meltage. My weener model seems to melt at a fast enough rate for me.
BTW, my hacked DC pads are not glued at all. I don't think it's a mandatory step if you aren't going to be man-handling the boards or wires.
  • Last login:February 05, 2026, 10:50:22 am
« Reply #2 on: July 11, 2005, 08:54:48 pm »
I do a lot of pads for people, so I like to hot glue the wires down just to make sure they don't come loose.  If you are hacking your own pads, I would probably reccomend that you do it, too.  It makes it a lot less liable to pop off.  As for what kind of glue gun, I bought a cheapo $2 gun that uses mini glue sticks.  It does the job just fine, and the refills are cheap, like $3 for 100 sticks.
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #3 on: July 11, 2005, 10:11:45 pm »
I use a cheap one I got at walmart.  I really don't think there is anything to be worried about.  But just in case there is, don't press the gun aganist the board and don't put any glue on the chips.
krion
  • Last login:January 13, 2021, 01:18:20 pm
« Reply #4 on: July 12, 2005, 10:44:55 pm »
i used a cheapo one as well which uses mini sticks.
pointdablame
« Reply #5 on: July 13, 2005, 11:38:49 am »
I don't think it is really going to matter much.  If you'd like, they make low temp hot glue guns for modelling, which is what I use.  I've also used just a regular old hot glue gun in the past and had no problems.  Just make sure the tip doesn't sit on the PCB itself (which it should never do anyway).
first off your and idiot
forbiddenlyrics
  • Last login:July 10, 2010, 03:19:34 pm
  • I'm Bart Simpson Who The Hell Are You?
« Reply #6 on: July 16, 2005, 02:26:48 am »
I too have used a cheap walmart hot-glue gun to hold wires on a PCB. Just head down there or to a craft store and pick up the cheapest one they have.
