Author Topic: cocktail cab  (Read 1059 times)
mrfuller8
  • Newbie
  • Last login:July 18, 2005, 08:53:46 am
cocktail cab
« on: July 10, 2005, 09:50:35 am »
my first post (noob) so be gentle (ha).
i have almost competed my first cab. Cocktail pacman refurb (was completely trashed) and added a horizontal side with trackball. I am running mame32 and mamewah. However, I want to use mamewah for nes,snes,atari etc AND still use mame for the aracde roms.
Is there a way to run like a "PRE-FRONTEND" @ startup that allows me to select between  mame/daphne/mamewah/jukebox. (having issues getting daphne to run with mamewah). Kinda like a frontend for my frontends? (dumb i know, sorry)
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: cocktail cab
« Reply #1 on: July 11, 2005, 03:40:26 am »
You can use my Front End to do that.  It would be funny to see Atomic as Front End for Mamewah!  ;)
But i'm sure MameWah should do what you want itself without the need of a frontend for the front end.
If you can not with MameWah , you can do that without problem with AtomicFE.
You create a Config for each of yours emulator / Jukebox or what you want, and you use my MulticonfWizard to build your config seletors as you want.
