Author Topic: Can/Should games in mame play at 800X600?  (Read 1973 times)
thetered
  • Last login:April 12, 2011, 02:29:57 am
  • Dirty!
« on: July 07, 2005, 12:42:18 pm »
I have XP and mamewah to run at 800X600 with no problems but when I launch a game it scrolls, so I went to the games (metal slug X) ini file and changed the res from 620x480 (or something like that) to 800x600 but the game still scrolls when I launch it.
I am using an old wells 19in monitor with arcade vga...
« Last Edit: July 07, 2005, 08:09:14 pm by thetered »
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re: Help with mamewah/xp V Hold
« Reply #1 on: July 07, 2005, 12:48:06 pm »
Make sure that the resolutions for XP and MameWah are the same. If they are different, than the hold settings on them are different.
thetered
  • Dirty!
« Reply #2 on: July 07, 2005, 06:11:24 pm »
How do I check that for mamewah?  ???
thetered
  • Dirty!
« Reply #3 on: July 07, 2005, 06:57:03 pm »
nm i figured it out, thanks!
thetered
  • Dirty!
Re: Can/Should games in mame play at 800X600?
« Reply #4 on: July 07, 2005, 08:09:49 pm »
fixed first problem so changed the topic and question.
Minwah
    • MAMEWAH
« Reply #5 on: July 08, 2005, 06:45:43 am »
No, don't use 800x600 on an arcade monitor.  You should use low-res modes, as the ArcadeVGA is inteded (eg 321x240, 368x240 etc...)
Try my MAME Resolution Tool to generate suitable ini files for you to achieve this.
Lilwolf
« Reply #6 on: July 08, 2005, 08:55:34 am »
btw, this is because arcadevga -> arcade monitor supports 640x480+ but in interlaced mode.  This makes the monitor draw every other line every pass... Then the next pass it does the other.  This gives flashing and is very annoying.
640x288 I believe is the highest resolution that you can get without interlaced mode.
Minwah
    • MAMEWAH
« Reply #7 on: July 08, 2005, 09:32:41 am »
Yep, but I find this mode a bit useless personally.
Of course the interlaced modes are of use, for fitting medium/high res. games onto a standard res. screen.  Or squashing vertical games onto a horizontal screen...but otherwise you should use the low-res modes.
