Author Topic: computer spec help  (Read 1101 times)
joshbr7257
  • Last login:August 15, 2006, 10:12:28 pm
  • B.Y.O.B.!!!!!!!!!!!
computer spec help
« on: July 05, 2005, 06:58:14 pm »
ok i know i had a post like a week ago asking if i should buy a 1GHz tbird, well i bought it, and now im wondering what version of mame should i run on it? do you think id be able to run mame 97 good? oh yeah i forgot in the cp will have a 1GHz proccessor like i said before with 400mb something ram, almost 512mb. so should i just run mame 61 or go for mame 97? thanks
oh yeah forgot to ask, what about the CHD files? can i run those? if i go with 97? thanks
WANT A FREE PSP? CLICK BELOW.
http://www.FreePSPs.com/?r=17776949
tommy
Re: computer spec help
« Reply #1 on: July 05, 2005, 08:37:59 pm »
joshbr7257
« Reply #2 on: July 05, 2005, 11:11:17 pm »
yes ive seen that but i wanted people opinions
pointdablame
« Reply #3 on: July 06, 2005, 12:09:06 am »
I personally would run a full set of Mame .55 roms on it, and have a .97 install on it as well for the few games worth playing since then, or the few that were "fixed" like Galaga.  You won't be able to play all the CHD games of course, but there are probably enough games from .55 --> .97 that might warrant the two versions.  Golden Tee comes to mind... but I don't know if that'll run on your system (I haven't even tried them out yet, I'm still using .69 or so).
That's my .02
first off your and idiot
joshbr7257
« Reply #4 on: July 06, 2005, 12:36:21 am »
but do you think that the .97 version would run ok? if so why would i need .55 or .61? im not really interested in any games that use the trackball like golden tee , also not really interested in the really old games like donkey kong and all those, i want to be able to play all the metal slugs up to ms4 unless i ca play 5 to? and i want marvel vs capcom are those on the .61 version?
pointdablame
« Reply #5 on: July 06, 2005, 12:05:19 pm »
1ghz is on the edge as to whether you will be playing full speed or not.  As I mentioned, I have not used .97, but my guess is that it probably won't run that great on your system.  My suggestion of using .55 was so that you could have 99% of the games that are currently in mame with .55 (percentages might be wrong, but almost everything is in there)... and most importantly it'll run great on your system.  I have a 950mhz bartop running .55 and everything except for maybe 5 trouble games runs perfect.  I know it has a few Metal Slugs on it, but I think 3 and 4 might have been released after .55.
By having most of your games on .55, your system shoudl run the games much much faster.  Then, try .97 for the few newer games you wanna play and see how it works out.  That way, almost all of your games will be running under .55 with little or no problems, and you can test out other versions for the other games you want to play.  It's super simple to run multiple versions of mame on teh same computer, and that way, you can get your games running at their best for your system.
joshbr7257
« Reply #6 on: July 07, 2005, 12:33:40 am »
yeah i think im going to expiriment with diff versions once i get some time, i was recomended version .61 by someone else i think ill try that version first. thanks for the help
