Author Topic: please help me! ddr clone with septmania  (Read 1907 times)
EvilRyu
  • Last login:November 30, 2006, 02:21:43 am
« on: July 01, 2005, 05:25:58 pm »
hi! my trouble is the video system in the ddr machine. i have the stepmania program in my pc. i want see in the arcade monitor, but the horiz refresh of my video card is distintc a 15khz. i have the powerstrip program but i don`t know if this program in software mode could damage my arcade monitor. the arcade vga is posible but idont have founds rightnow. it`s for testing the possibility of the clonation. forgive me  :-[  for my translation. thank`s!! ;)
AlanS17
    • AlanS17
Re: please help me! ddr clone with septmania
« Reply #1 on: July 01, 2005, 05:33:29 pm »
Ok, let me see if I understand. Maybe I can clear everything up.
You have a DDR machine, but you want to put a PC with Stepmania inside it. You want to play Stepmania on your DDR machine. You are afraid of damaging your monitor because the sync rates are different in your PC and your arcade monitor. You don't have an ArcadeVGA video card because they are expensive so you want to use Powerstrip.
Does that all sound correct?
AlanS17
    • AlanS17
« Reply #2 on: July 01, 2005, 05:34:01 pm »
By the way, welcome to the boards! (And Ken is better than Ryu.)  ;)
EvilRyu
« Reply #3 on: July 02, 2005, 10:31:52 pm »
ok, i only want  to know if the powerstrip don
tokyogameaction
  • Last login:February 11, 2012, 10:47:07 pm
« Reply #4 on: July 03, 2005, 03:45:05 pm »
I built a stepmania machine for our arcade. I used power strip, but the video was a lil ugly looking. It wont damage the monitor, just wont be too too crisp. I use an ArcadeVGA and it works great. The other issue you may run into is mapping the arrows. Most machines will not work with a j-pac. If you have any issues with that IM me on either sn: TPMWR or TPMWR2 . As I said, our arcade (Tokyo Game Action) has a stepmania machine as our machine.
Anthony
www.TokyoGameAction.com
