Author Topic: Speaker Location  (Read 2000 times)
MrD
  • Last login:May 20, 2020, 04:34:05 pm
Speaker Location
« on: June 30, 2005, 04:24:51 pm »
In a bubbler-type Jukebox, (Wurlitzer etc) where were the speakers located? I'm going to try and build one similar to that.
The only place I can see is maybe in the center underneath the controls.  That area might be fabric and the speakers are housed behind it?  Inside the "U" lighting?
I know that a subwoofer location isn't as critical because bass is non-directional.  But what about the other speakers?  I always thought speakers should be at about ear level.  Even sitting that area seems a bit low, and then doesn't the left and right channels get mixed since they are so close together?
If I mount the speakers pointing out the sides, then I'm afraid you'll only hear one channel.
Does anyone have any thoughts on where the speakers should be located?
MrD
Re: Speaker Location
« Reply #1 on: July 15, 2005, 09:49:21 am »
I found my own answer.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: July 16, 2005, 12:21:35 pm »
The Rowe-Ami/Antique Apparatus reproduction "Bubbler" models have the speakers mounted on the front door just as in the original Wurliter 1015 from the 1940's did.
