Author Topic: Guncon 2 holder  (Read 1399 times)
peanut
  • Last login:November 11, 2009, 01:47:29 pm
  • arcade nut
Guncon 2 holder
« on: June 29, 2005, 10:29:45 pm »
Does anyone know if a Guncon2 will fit the Gunholders found on happscontrols seen here: http://www.happcontrols.com/amusement/optical/96075016.htm
I was thinking about getting the cheap 19.95 one, but i dont know if it opens up at the top enough.
peanut
  • arcade nut
Re: Guncon 2 holder
« Reply #1 on: June 30, 2005, 01:58:12 am »
anyone?
stevodevo
  • Last login:March 07, 2022, 11:27:18 am
Re: Guncon 2 holder
« Reply #2 on: June 30, 2005, 09:40:38 am »
With as new as the whole GunCon2 thing is - you're probably going to end up being the guinea pig! :)
I'm thinking of constructing something since I need mine side-mounted and those look like they mount on top.
Goz
  • KOTA
Re: Guncon 2 holder
« Reply #3 on: June 30, 2005, 10:06:49 am »
The Guncon will not fit in the HAPP holsters you have listed. The Barrel is simply too large.
-Goz
