Author Topic: centipede volume pot and test switch specs?  (Read 5060 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: June 28, 2005, 07:52:29 am »
i have just bought complete centipede wiring loom but notice that the volume pot has been damaged beyond recognition and there is no test switch fitted :(
wondering if anyone knows the specs of either, so i can get modern equivalents?
would appreciate any pics as well
cheers
- richard
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: centipede volume pot and test switch specs?
« Reply #1 on: June 28, 2005, 10:08:25 am »
I doubt it matter what you use for the test switch, since it will be a low voltage (+5?)
NO MORE!!
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #2 on: June 28, 2005, 10:21:25 am »
Checked the Centipede manual and it just list it as a vol. pot.  The drawing package isnt much help either...Ill check my Centipede later today and see if it has anything on the pot.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 28, 2005, 10:23:52 am »
Here is what Atari originally used:
Ohmite # RES-100 Power Wirewound Rheostat, 100 ohms (the volume control)
CW Industries # GF-624-6014 Slide Switch, S.P.D.T. (the test switch)
Both of these are available at mouser.com as the part numbers 629-GF6246014 (50 cents) and 588-RES-100 ($22.59)
rchadd
  • Made in Cornwall
« Reply #4 on: June 28, 2005, 10:41:21 am »
thanks ken
i'm in the UK so will try and find a local supplier
Ken Layton
  • Guru
  • Technician
« Reply #5 on: June 28, 2005, 12:51:26 pm »
I'm sure you should be able to find local suppliers of those well-known manufacturers or at least be able to cross reference those part numbers to an equivalent part.
Paladin
  • Mmmm llamaburgers!
« Reply #6 on: June 28, 2005, 10:37:34 pm »
On Tempest, the test switch is on the coin door.  Is Centipede the same way?
Ken Layton
  • Guru
  • Technician
« Reply #7 on: June 29, 2005, 12:33:27 am »
Not neccessarily. I've seen many Centipedes with the test switch and volume rheostat mounted on a bracket inside the cabinet next to the coin door hinge. I've seen a couple with the test switch mounted on the coin door, but that was only on COINCO brand doors. The cabinets were wired for test switches at both locations so you could use either area.
