Author Topic: Monitor problem please help  (Read 1310 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: June 27, 2005, 12:52:52 am »
ok in my golden tee machine i have a picture that if the vertical size is placed all the way up to the correct size on the screen it looks like the picture is rolled over at the top of the screen...at that point is a little like it is transparent. the monitor is a wells gardner 25" standard resolution...coincedently my tv has the same problem...will a cap kit help this opr is this something different
Ken Layton
  • Guru
  • Technician
Re: Monitor problem please help
« Reply #1 on: June 27, 2005, 01:08:33 am »
If you have a Wells-Gardner k7000 series monitor then adjust the 50/60 hz trimpot.
GMZombie
« Reply #2 on: June 27, 2005, 02:43:54 am »
hey man that worked....now can you help me with my sharp tv it has the same thing...but i looked and there isnt a 50-60hz trimpot unfortantly...any answers
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 27, 2005, 10:55:03 am »
I'm not into home tv sets. Home stuff (anything that sells for less than $400) just isn't made to be repaired anymore. Generally, from what you describe on that set it probably needs some capacitors so get out the capacitor tester and check 'em all.
 My experience is with commercial arcade monitors (made to be repaired).
