Author Topic: What size T-Molding with a laminated surface?  (Read 1529 times)
ITrek
  • Last login:January 06, 2009, 10:18:26 pm
« on: December 16, 2002, 10:29:41 am »
If 5/8" wood is used to build a cabinet and lamination is added increasing the width by 1/16"+, does it look better if you use 3/4" T-molding or 5/8"?
What would happen if the whole world farted at the same time?
Chris
    • Chris's MAME Cabinet
Re:What size T-Molding with a laminated surface?
« Reply #1 on: December 16, 2002, 10:46:00 am »
I used 5/8" wood and 1/8" lucite with 3/4" T-molding.
You can see how they fit together on one small exposed corner of my control panel:
--Chris
--Chris
Madman
  • Last login:September 01, 2017, 01:03:20 pm
« Reply #2 on: December 17, 2002, 01:03:57 pm »
I used 3/4 for my 5/8 that has been laminated.
It came out VERY well. I also used a T-molding trimmer from t-molding.com
If you do buy the trimmer make sure you test it first and round any sharp edges off before trimmer your expensive cabinet! ( it has some sharp edges that can damage the t-molding if you do not round them)
