Author Topic: Metalhead has a FE/monitor issue :o  (Read 1221 times)
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« on: June 24, 2005, 03:01:33 pm »
OK fellas, here it is. Lets start with what I'm running, then we'll get to the issue I'm having:
  • MSI mobo/Athalon 64 3000+
  • 256 Ram
  • ArcadeVGA (the newer model)
  • 25" Hantarex Polo tube with 8liners chassis
  • Windows XP Corp Edition.
I have MameWah, GameLauncher, and AtomicFE setup on a fresh XP install. The video on the desktop is set to 640x480 (the lowest Windows allows), and the screen size/position/refresh rate are set. All 3 emulators work fine booting up, running games, and exiting back to the desktop.
The problem:
While in any of the FEs, if I select a game like Mario Brothers (1983) it runs fine, but if I select something newer (25kHz?) like Marvel vs Capcom, it stretches vertically and throws the refresh rate out the window (the image jitters up and down).
Is there a paramater I've missed somewhere in all 3 FEs to prevent this from happening, or could it be something hardware related, like my monitor or the AVGA?
Signature tags are dumb.
M3talhead
Re: Metalhead has a FE/monitor issue :o
« Reply #1 on: June 26, 2005, 11:37:17 am »
Fixed
SirPeale
  • Green Mountain Man
« Reply #2 on: June 26, 2005, 02:12:56 pm »
Typically the best thing to do is when you find a solution is to post the solution here in your own thread.  That way, if anyone else has the same problem, your solution may possibly help.
