Author Topic: Simplest way to make a PS2 joystick  (Read 5047 times)
RacingFB
  • Last login:December 31, 2002, 10:37:05 pm
  • needs a joystick set-up
« on: December 15, 2002, 10:56:58 pm »
I want to make a joystick to be used solely with PS2, what would be the simplest way to go about this?
I'm looking for an 8-way joystick with a circular internal motion (I'd prefer to spend extra to get one with good action because I'll be using this for Tekken 4 and other fighting games where I'll be doing many quick circular motions)  Any suggestions or links to debates would be much appriciated.
It would also be great if there was a way to canabilize one of my existing PS2 controllers into this new controller.  I looked at the internals of both my game pad and crappy joystick I recently bought.  They both use the bottom of the buttons to complete a circuit on the board itself.  The stick however does have 5 wire input points for the joystick, so that part would seem simple.
RacingFB
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
Re:Simplest way to make a PS2 joystick
« Reply #1 on: December 15, 2002, 11:17:33 pm »
UMM....ever heard of a super joystick from happs..that one is pretty smooth and hack a cheap $2 psx game pad that works with ps2 and play all the tekken you want. :)
yehhh ! ! ..its not as easy as i am makin it sound but hey..you can do it. ;)
RacingFB
« Reply #2 on: December 16, 2002, 02:20:16 am »
Thanks for the info, I found a site that has the basics of soldering onto the push button style printed circuits of the PSX controllers
Anyone else have any comments about the best stick for good circular motion?
RacingFB
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #3 on: December 16, 2002, 02:55:49 am »
I think the competition Joystick from Happs is the best for fighting games.  It will get you all the circular motion you will want.
Don't try to hard to hack the analog functions of the PS2 Dual Shock2 controllers...
hotboy_92
  • Last login:January 07, 2003, 03:49:29 am
« Reply #4 on: December 16, 2002, 05:05:34 am »
What's wrong with hacking the DS2 analog controls? I'm in the process of doing just that.
BTW, I'd be interested in the link on soldering racingfb.
RacingFB
« Reply #5 on: December 16, 2002, 05:32:03 am »
Here ya go, http://axelb.free.fr/caj/psx.html
Now will I have to hack a non-analog PSX pad, I figured it wouldn't make too much difference because input switches from happs would just send the max signal when the button was pressed.
Any suggestions here for good PSX pads to hack, I'm looking for a pad where the circuit board is directly under the buttons, this is the style demonstrated in the above link.
The Dual Shock 2 has the input pad separate from the board which I can see as a possible plus.  I could trace the wires back from the input pad and wire to them.
hotboy, how you doin hackin the DS2 whoodi?
RacingFB
toilet
  • Last login:November 11, 2005, 11:53:45 am
    • Briefcase Emulator
« Reply #6 on: December 16, 2002, 07:16:41 am »
I recommend the cheaper / larger 3rd party PSX controllers. The official sony ones come with a carbon film over the contacts that is an unnecessary pain to deal with.
If this is for a SF variant purpose I also recommend happs competiton buttons (the convex ones) and the competition joysticks. You may want to get a loose and tight spring for the sticks while you're ordering. They're only like 18 cents and you may never use them, but it's good to order them now since happs has a $25 minimum order.
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #7 on: December 16, 2002, 11:31:23 am »
for my street fighter style setup i use happs ultimates (make sur eto get the stiffer springs, its a MUST) the regular happs horizontal push buttons, and a cheap old  gamestop brand ps controller, it has no analog but for my fighting games i dont use analog anyways.
save yourself a headache and drill a small hole thru the pad you are goin to solder thru and thread the wire thru from the back, it makes it so much easier and nicer looking, you can check pics of mine if you want i will offer any advice or help you need
http://www.cosmicbreaks.com/images/arcade_stick/padhack
m3talslug
  • Last login:February 07, 2007, 04:22:25 pm
  • I want to Build My Own Arcade Controls!!
    • M3talslug's Control Panels
« Reply #8 on: December 16, 2002, 12:15:42 pm »
Actually only the Supers and the P360s have a circular motion.  The Ultimates and COmpetitions have a square actuator which give it a square motion.
SNAAAKE
  • -Banned-
« Reply #9 on: December 16, 2002, 03:33:51 pm »
Well..thats what i said to begin with :D.
Go supers if you cant afford perfect 360s.
RacingFB
« Reply #10 on: December 16, 2002, 07:24:03 pm »
Alright, I need a little clarification on this.
It seems to me from looking at the exploded views on the Happs site that either the bracket or the actuator could give it a circular motion.
So the question is, does the actuator or the bracket restrict the motion of the stick.  Speaking from a purely engineering point of view I'd guess its the bracket to save on wear and tear on the microswitches.  However if the bracket is the attachment and pivot point of the stick it wouldn't have any affect.
So of the conflicting opinions here which of you are speaking from ownership/experience?  Snaake, I saw you made a couple setups which stick did you use, and how do you like it?
If the P360 is the only bat shaped handle with circular motion I'd be happy to drop the extra dough on that.  But of course if I could use a comp or ultimate instead I don't wanna waste $ on something I don't need.
RacingFB
« Last Edit: December 16, 2002, 08:50:17 pm by RacingFB »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #11 on: December 16, 2002, 08:11:47 pm »
could always get that arcadeish stick from liksang.com
SNAAAKE
  • -Banned-
« Reply #12 on: December 16, 2002, 08:57:48 pm »
well,
To be REALLY honest...super joysticks are great.i built sticks with ultimate,comp,supers and best are supers.However,i used to have 360s long time ago and they are the best out of any joystick and the best part is you can use that sensor hub for comp and supers.just in case you didnt like the super joystick shaft,the perfect 360s would let you use comp shaft and you get "NO CLICKING" setup.
if i were to suggest anything here,i would say go for supers as they are the best you can get for your money.
Also they are on special from happs.we all paid $13 a piece and now they are $7.show us pics when things get moving. ;D
SNAAAKE
  • -Banned-
« Reply #13 on: December 16, 2002, 09:00:05 pm »
EWW :-[...
isnt it BUILD you own?NOT buy crap from lik-sang. :P
I am not pickin on you but why would anyone here wanna buy those crappy plastic joysticks...again..EWWW.. :P
« Last Edit: December 16, 2002, 09:04:54 pm by SNAAAKE »
RacingFB
« Reply #14 on: December 16, 2002, 09:05:21 pm »
I just bought an arcadish stick the other day which is what sent me on this quest to build my own to arcade spec.  Thanks for the heads up on the website though, lots of goodies there.   ;D
RacingFB
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #15 on: December 16, 2002, 09:40:41 pm »
RacingFB
have you looked at the x-arcade stick at all yet?  Of course it isn't build your own (although they do have kits available if you are so inclined)  ... but it interfaces with ps2  (and other consoles) not sure how/if it handles analog stuff...
Good luck!
Rampy
SirPoonga
  • Puck'em Up
« Reply #16 on: December 16, 2002, 10:07:52 pm »
EWW :-[...
I've never had issues with liksang.
I know this is build your own arcade controls, but if something already exists that isn;t bad why go through the extra work when it is a difficult thing to do from the start?
If oyu don;t like liksang there is always redoctane.com.
« Last Edit: December 16, 2002, 10:18:18 pm by SirPoonga »
RacingFB
« Reply #17 on: December 17, 2002, 01:03:00 am »
I've seen the X-Arcade controls.  They look pretty sweet and it basically came down to the economics of it for me, I could make a top of the line set up for $60-70 where as I'd pay $100 for a single player X-Arcade and have no idea what parts went in it.
I just ordered a P360 and 8 horizontal microswitches.  I'll be starting this project next week after finals, so hopefully I'll have some pics early next month.
I also just wanted to thank everyone that's helped me out so far by posting.  Thanks for all the great info guys   :)
RacingFB
