Author Topic: Can I use a 14v lighted button with IPAC led outs?  (Read 1366 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: June 24, 2005, 12:11:38 pm »
Basically I plan on using these buttons on my mini CP
http://www.happcontrols.com/pushbuttons/5400042x.htm
see pic below.  It uses a 14v incandescent bulb (or a 12v LED)  What I'm wonderin is if I can hook the power up to my computer for the 12v and still hook it up to the ipac so it blinks and lights acording to scroll lock and caps lock on the IPAC in MAME(tm)
Thanks for any help
tim
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
Re: Can I use a 14v lighted button with IPAC led outs?
« Reply #1 on: June 24, 2005, 12:23:37 pm »
I'm not sure what voltage the I-PAC outputs, but just wanted to say that I run these (14v bulbs) on a 9.6 volt transformer (remember all of those 9.6V Turbo Power! RC cars?).
So, I know that didn't answer your question, but just wanted to say that these are plenty bright with ~ 9.5 volts instead of 14.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: June 24, 2005, 12:55:45 pm »
I figure that I'll have to power the lights from somewhere other than the IPAC.
But what about controling the lights from the IPAC?
So that it blinks when a coin is inserted into slot one or whatever?
Will that be possible?
whammoed
  • Last login:January 31, 2026, 10:01:01 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: June 24, 2005, 12:59:25 pm »
yes its possible, but you will need something like the led driver board that gamecab sells.  You will have to modify the design for your application.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: June 24, 2005, 01:00:13 pm »
or a relay, but I'm not sure of the specs you would need for one.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #5 on: June 24, 2005, 01:22:04 pm »
How would I modify the gamecab led driver?
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
« Reply #6 on: June 24, 2005, 01:42:43 pm »
I just did this last week. Here's the thread, there's a cut-n-pasted circuit diagram at the bottom of the page:
http://forum.arcadecontrols.com/index.php/topic,37270.0.html
It works great. I'm using it to control a light and coin lockouts (so now when the wife puts tokens in when the frontend is running, they go straight to the coin return)
