Author Topic: Mamewah running multiple instances of zsnes?  (Read 1363 times)
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
« on: June 21, 2005, 04:01:08 am »
I've been fine tuning mamewah and discovered that when running zsnes and quitting manually everything is fine.  However, when using the screensaver option run random game and quit, mamewah doesn't actually kill the process.
After leaving mamewah on my snes list for a couple hours it began running games like a slideshow, so I checked task manager and found about 30 instances of zsnes running.
Here is my snes.ini file and I have disable the zsnes gui.  Any ideas?
### 3-snes.ini (mamewah v1.61) ###
emulator_title                            Super Nintendo
### List Generation Settings ###
rom_path                                  c:\arcade\roms\snes
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           c:\arcade\config\system\mamewah\catsnes.ini
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\arcade\config\snes\zsnes\zsnesw.exe
commandline_format                        "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\arcade\config\snes\zsnes\snaps
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                run_random_game_and_quit
movie_path
movie_fullscreen                          1
quit_delay                                100
wrapper_executable                        c:\arcade\config\snes\zsnes\zsnesw.exe
wrapper_commandline_format                "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable                          c:\arcade\config\system\cpviewer\cpvw.exe
app_1_commandline_format                  -b=c:\arcade\config\system\cpviewer\snes.png {music}
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path                                c:\arcade\external
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
Re: Mamewah running multiple instances of zsnes?
« Reply #1 on: June 21, 2005, 06:03:02 pm »
Not sure...and I can't test it atm :(, but I've added it to my 'to look at' list...
Anyone else have the same problem?
