Author Topic: AVRES and vector games issue  (Read 1088 times)
pacman
  • Last login:October 01, 2007, 09:51:35 am
« on: June 14, 2005, 03:52:33 pm »
Quick question : do you know why AVRES utility do not create a correct INI file for vector games ? INI's for vector do exist but without a resolution and consequently games do not launch properly.. ::) ::) (image is cropped and/or not centered on the screen)
I am using the arcade VGA + Hantarex monitor MTC9110.
2600
Re: AVRES and vector games issue
« Reply #1 on: June 14, 2005, 04:15:20 pm »
Probably because it's only one file.
Creat your own vector.ini with the resolution you want.
pacman
« Reply #2 on: June 14, 2005, 04:44:33 pm »
Thanks for your reply 2600; Do you mean I need to create only one ini file for all vector games ? What is the best resolution to use then ? ???
2600
« Reply #3 on: June 14, 2005, 05:22:11 pm »
I can't answer the best to use.  Best is generally subjective and is always dependent on your setup, which you have not provided any info on.
Higher is better, and I'll let you figure out the rest.
pacman
« Reply #4 on: June 15, 2005, 03:01:23 am »
Well I am using Mamewah in 640x480 with Mame 0.93 Windows command line.  The monitor is 25''...
