Author Topic: Parts needed for Gamepad Hack?  (Read 2156 times)
samsunnyuk
  • Last login:June 15, 2005, 01:03:48 pm
« on: June 13, 2005, 07:00:52 pm »
Hi, could someone please list me the parts I need to wire up Aarcade buttons to a Gamepad? Thanks in advance
quarterback
Re: Parts needed for Gamepad Hack?
« Reply #1 on: June 13, 2005, 07:02:07 pm »
1. Gamepad
2. Buttons
Okay, I got the list started, anyone wanna' take it from there? :)
3.
4.
5.
-- Chad Tower
  • Last login:Yesterday at 04:39:53 pm
« Reply #2 on: June 13, 2005, 07:03:15 pm »
3.  Wire
4.  Solder
5.  Soldering Iron
6.  QD's from Peale
7.  Sandpaper
8.  Hot Glue
samsunnyuk
« Reply #3 on: June 13, 2005, 07:05:00 pm »
Whats QD, and whats the hot glue for?
samsunnyuk
« Reply #4 on: June 13, 2005, 07:13:44 pm »
annnyyoneeee???  ???
NoOne=NBA=
« Reply #5 on: June 13, 2005, 07:26:17 pm »
QD is quick disconnects.
The hot glue is to secure your wires AFTER you solder them, to keep them from pulling back off of the gamepad PCB.
« Reply #6 on: June 13, 2005, 07:27:21 pm »
Yeah, what he said.
samsunnyuk
« Reply #7 on: June 13, 2005, 07:31:59 pm »
what would i search for the QD's as on google (to buy some)
pointdablame
« Reply #8 on: June 13, 2005, 07:32:58 pm »
wire disconnects or wire quick disconnects.
Or better yet.. just go to the B/S/T forum and buy some from Peale.
first off your and idiot
samsunnyuk
« Reply #9 on: June 13, 2005, 07:34:37 pm »
ok cheers, im in the UK by the way  ;)
samsunnyuk
« Reply #10 on: June 13, 2005, 07:37:16 pm »
do i need Female QD's?
« Reply #11 on: June 13, 2005, 07:38:27 pm »
Yes, as the buttons and joysticks have male terminals
samsunnyuk
« Reply #12 on: June 13, 2005, 07:40:23 pm »
and just to confirm; each arcade button has two wires coming from it?- one to the ground and one to the actual button (on gamepad)
« Reply #13 on: June 13, 2005, 07:52:16 pm »
Ermm, I'll say yeah, but you need to find what side of each button (on the gamepad PCB) is the ground.
samsunnyuk
« Reply #14 on: June 13, 2005, 07:54:55 pm »
ok kool, and what sort of wire and solder should I use?
« Reply #15 on: June 13, 2005, 08:06:48 pm »
22 guage wire, and a solder with a rosin core.
samsunnyuk
« Reply #16 on: June 13, 2005, 08:11:44 pm »
ok thanks for all  the help people!  ;D ;D
