Author Topic: what tool for cutting diagnal?  (Read 1906 times)
alundra
  • Last login:February 02, 2009, 09:30:05 pm
« on: June 12, 2005, 01:07:08 am »
i need to know a proper tool for cutting diagnal edge clean and smooth
like this http://us.f3.yahoofs.com/users/41b556e7zc1e5483b/5cbb/__sr_/1e99.jpg?ph6a8qCBtJFjWCfy
thanks
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
Re: what tool for cutting diagnal?
« Reply #1 on: June 12, 2005, 01:18:54 am »
A table saw will do this if it's a model with a tilting blade.
This is called a bevel cut.
Depending on the angle you want, you can also get a router bit, called a chamfer bit, at the correct angle and use that.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: June 12, 2005, 01:19:31 am »
It depends on the piece of wood you want to cut. If it is only 4" or so you can use a "chop saw" or Mitre Saw like this
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: June 12, 2005, 01:21:51 am »
Or for pieces larger or wider than 4" You should use a table saw like tivogre suggested
they look like this.  They range from $119 to $3000. And you get what you pay for.  the $300-500 range should suit you fine for quality, accurate cuts.  If you're not going to be building much more than your arcade cabinet, this option might be a bit much.
With patience and planning a circular saw can give you "good enough" results and save you alotta $ and space.
« Last Edit: June 12, 2005, 01:27:19 am by timoe »
tivogre
    • ogredog.com
« Reply #4 on: June 12, 2005, 01:24:27 am »
ooh!  ooh!
If we're doing pictures, here's a chamfer bit:
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #5 on: June 12, 2005, 01:24:34 am »
If you're buying saws you NEED on of these..,
A circular saw.
alundra
« Reply #6 on: June 12, 2005, 01:25:39 am »
they look like this
that thing look expensive..how much is it?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #7 on: June 12, 2005, 01:29:13 am »
see the above post (edited) for table saw price.  You can get a decent circular saw for $80 (including blade)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #8 on: June 12, 2005, 01:30:39 am »
I would strongly recommend this thread (if you haven't read much of it already)
http://forum.arcadecontrols.com/index.php/topic,19049.0.html
there is MUCH to read there but take your time and you will learn VOLUMES!!!
I still go back to this thread from time to time when I realize something else i dont already know about
alundra
« Reply #9 on: June 12, 2005, 01:32:27 am »
does the $80 circular saw have the bevel cutting? and what tool use this bit?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #10 on: June 12, 2005, 01:35:02 am »
its a router that uses that bit ^
You "should" use a router to make the slot cut for your t-molding.
If an arcade is the only thing you'll be using all these tools for though, I would really suggest finding a friend with the tools who might like to help you out.
I cant stress enough the FAQ thread, I'm addicted to it  ;D
« Last Edit: June 12, 2005, 01:38:50 am by timoe »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #11 on: June 12, 2005, 01:36:18 am »
Most circular saws ($80) have adjustable blades for both depth and angle (for bevel cuts)
crashwg
« Reply #12 on: June 12, 2005, 01:54:58 am »
WTF is "diagnal"?
:police: :P :police:
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
AlanS17
    • AlanS17
« Reply #13 on: June 12, 2005, 01:56:51 am »
You mean I'm thew only one who uses his teeth?  ???
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #14 on: June 12, 2005, 11:14:15 am »
Nope. I use a crack team of specially trained beavers.
