February 01, 2026, 08:14:55 pm
is there a way using shift you can program an ipac pcp to allow you to press control and tab to switch between apps running on an arcade cab?
Quote from: eggedd2k on June 09, 2005, 03:37:36 pmis there a way using shift you can program an ipac pcp to allow you to press control and tab to switch between apps running on an arcade cab?Don't know what a pcp is, but you can assign a macro to a button with the latest Win-IPAC software. I think you right-click on the button and there's an option for it.
Quote from: Tiger-Heli on June 09, 2005, 03:44:29 pmQuote from: eggedd2k on June 09, 2005, 03:37:36 pmis there a way using shift you can program an ipac pcp to allow you to press control and tab to switch between apps running on an arcade cab?Don't know what a pcp is, but you can assign a macro to a button with the latest Win-IPAC software. I think you right-click on the button and there's an option for it.Macro function! Thanks for the heads up. This opens up so many possibilties for me
If you're just mapping the buttons to the seperate keys, why do you need macros?
