Author Topic: high pitch sound coming from monitor?  (Read 1118 times)
keltech
  • Last login:July 07, 2005, 09:09:20 pm
« on: June 08, 2005, 05:03:34 pm »
hi can you help please
i have some games that are running in mame and arcadeoes but when i run some games there is a horrible high pitch sound coming from the pc monitor? other games its fine
have i got a faulty monitor or is a frequency thing?
i don't know how to fix it
thanks
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: high pitch sound coming from monitor?
« Reply #1 on: June 08, 2005, 09:59:51 pm »
Do you live in a high-rise?
Actually, do you have power that causes the lights to flicker and dim sometimes?
I have a Sony which I bought in '98. After a couple moves, it did what you described. When it did that, I was living on the 10th floor, and our power was a bit "dirty" (enough so that my power supply in my PC fried at one point). Anyways, I thought the noise was due to age and moving it around, but then I moved again, this time into a new house and now my monitor makes no noise at all. (maybe jostling it fixed it, or maybe the noise is a voltage symptom)
NO MORE!!
MonitorGuru
« Reply #2 on: June 08, 2005, 10:58:55 pm »
Since you say "some games" -- You're probably overdriving the scan rate of the monitor.. Get out the manual and see what it supports and then limit your graphics card and mame to only do what is in range.  You could fry the yoke or deflection circuitry if you're running it out of spec.
