Author Topic: what does the steel cable connect to?  (Read 1748 times)
rob1234
  • Last login:September 23, 2022, 07:40:58 am
« on: June 02, 2005, 11:53:39 pm »
There is a steel cable that sticks out from under my line noise filter. What should this be connected to?
MonitorGuru
Re: what does the steel cable connect to?
« Reply #1 on: June 03, 2005, 12:19:45 am »
Ground.  Usually it was an open braided cable and ran to the following places:
a) Start at the RF noise filter (as shown in the picture)
b) run to the back door kill switch metal plate
c) run to the frame of the monitor
d) run to the bolts on the inside of the coin door
e) run to the bolts on the metal control panel
f) optionally run up to the flourescent lamp fixture metal frame
All it is is a ground wire to ensure that any wiring faults will quickly be caught and head to ground instead of through something else (namely you)
PS: You should probably remove the 25 cent piece that is loged under the tab of the noise filter before THAT shorts something! :)
« Reply #2 on: June 03, 2005, 08:38:53 am »
That doesn't look like a quarter, it looks like glossy plastic.
rob1234
« Reply #3 on: June 03, 2005, 12:46:47 pm »
it was plastic, I had pulled it out right after I took the pic. I didn't notice it before hand.
