Author Topic: New to LED's, can you shed some light on this subject?  (Read 1531 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: June 02, 2005, 04:10:51 pm »
Sorry for the pun..
I ordered the GameCab LED driver board. I am not too up to speed on specs for LED's these days.
Simply, using that board, what type/kind of LED's do I need? I mean I know I want superbright, and believe that it can handle it. But they have different voltage and such, which would I go for and not fry something?
Thanks in advance.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: New to LED's, can you shed some light on this subject?
« Reply #1 on: June 02, 2005, 07:41:52 pm »
Here's a good place to get you up to speed on LED basics http://unclean.org/howto/led_circuit.html Yaknow...give a man a fish and all that 8)
chrisindfw
  • I drank what?
« Reply #2 on: June 02, 2005, 08:00:13 pm »
That helps a bit. Now I was wondering the limits of the GameCab board. Since it is a 5v current.
Druin
  • Last login:May 10, 2009, 02:30:37 am
« Reply #3 on: June 03, 2005, 01:24:15 am »
I don't know anything about that board but I'll throw some observations out. I looked all over the site and didn't see any specs on current capabilities but it looks like the outputs marked for super brite LEDs are just straight 5volt outputs with no current limit resistors, so you'd have to be responsible for looking up the specs on the LEDs you use.  If the LEDs are rated for 5volts, you hook them up straight to those 9 super brite terminals and ground (they are always on).  If the voltage is more than 5, you can't run them.  If the rating is less than 5, you need to see the rated current in the specs for the LED, then calculate a resistor to add in series with the LED:
(5 volt supply - Voltage rating of LED) / LED rated current = resistor to put in series.
THe other 3 LEDs look like they have transistor drivers and series limit resistors, but I can't see the resistor color bands on the board picture on the site so I can't tell what rating of current they would supply.  I guess we can assume that the resistors were calculated to handle your typical LED (not super brite maybe) which would run 1.x to 2.x volts at a few mA to 15-20mA of current depending.
So....super brite must go on the constant powered 5volt lines assuming they need more voltage/current than a normal LED, and you have to figure out if you must add protection.  Most other common LEDs should run safe on the 3 other outputs but who knows.  we don't really have specs for the board.
namedos
  • Last login:July 16, 2025, 07:15:23 pm
« Reply #4 on: June 03, 2005, 12:05:03 pm »
Take a look at Kevin's article at retroblast.com as he does his typical good job of reviewing a product.  These are the LED's that he used for his testing which should give you a good idea what to order:
RL5-W18030 White LED
RL5-W8045 White LED
RL5-W10015 White LED
RL5-RD1560 Red LED
RL5-B4630 Blue LED
RL5-RGB-ACC Color Changing LED
I recently placed an order for a few different single LED's from SuperBright but I haven't hooked them up yet.
Hope this helps!
