Author Topic: Certain games slow or jaggy?  (Read 2612 times)
shawshank
  • Last login:June 20, 2005, 04:57:34 pm
  • The cabinet won't cost that much. I promise!
« on: June 02, 2005, 01:59:26 pm »
I have problem running certain games such as Virtual Fighter or Tekken 3 using MAME .96u3. The sound is even delayed. I am running a fast system:P4, 512mem, ATI9800 video card. Any ideas?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: Certain games slow or jaggy?
« Reply #1 on: June 02, 2005, 02:09:33 pm »
It's mame.  Get a better emulator for those games like modeler or zinc.  mame doesn't use hardware exeleration, it isn't taking full advantage of the system.  Mame's goal is to document the hardware in the game, this included emulating the graphics processor.  Other emus made for playing games will use the computers GPU for display which will make things faster.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #2 on: June 02, 2005, 03:02:31 pm »
Is it correct that Mame runs Double Dragon with huge slowdowns because the original had them as well? I heard that you can use a cheat.dat to get around that? I've never used a cheat file so I don't really know the process.
SirPoonga
  • Puck'em Up
« Reply #3 on: June 02, 2005, 04:11:39 pm »
About double dragon, yes.  The original had slow downs.  you can use cheats to overclock the processors to "fix" that.  However, on these newer games you probably can't do that since you need extra processing power from your ocmputer.  With newer games the computer itself can not handle the emulation so there is no extra processing power available to overclock.
M.A.M.E Power
  • Last login:February 06, 2007, 04:25:59 pm
  • There Are So Many Games!
« Reply #4 on: June 03, 2005, 04:12:09 am »
Did not realise this was the course of the slow down!
So can these emulator be used by Mamewah? Also is there a source that provides a full list of the supported games so I can create a custom games list?
Dagg
  • Last login:June 05, 2017, 04:23:59 pm
« Reply #5 on: June 03, 2005, 08:30:02 am »
Wow I never knew that either I will need to look into zinc and modeler tonight, thanks for the info!
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #6 on: June 03, 2005, 10:39:12 am »
what are zinc and modeler?
Goz
  • KOTA
« Reply #7 on: June 03, 2005, 11:00:38 am »
Google is your friend....
I put in ZINC + EMU and here's one of the first links which should show you a number of emulators.
-Goz
Veinman
« Reply #8 on: June 03, 2005, 12:09:41 pm »
Nice link for a history lesson. That page needs updated. :)
  • Last login:Yesterday at 04:10:01 pm
« Reply #9 on: June 05, 2005, 03:44:29 am »
I would like to point out that modeler shouldn't be in the equation as it's:
Not cabinet friendly at all.
Won't emulate any of the games mentioned.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #10 on: June 05, 2005, 04:11:59 am »
... and most arcade games are jaggy by nature. The games are coded at a fairly low res, at least compared to todays games, so the jaggies abound. Hell, "jaggies" wasn't even really a term back in the heyday of the arcades, since they're was nothing to compare them to.
Playing Mame games on a PC monitor as well will further make the jaggies stand out since the monitor is far sharper than an arcade monitor.
