Author Topic: Carbon fiber cutting  (Read 1578 times)
rdagger
« on: May 31, 2005, 03:05:00 pm »
I picked up a scrap sheet of .05" carbon fiber that I am going to use in a new project.  Anyone know the best way to cut this stuff?
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
Re: Carbon fiber cutting
« Reply #1 on: May 31, 2005, 03:31:06 pm »
Is that the same as polycarbonate sheet material, ie Lexan? If so, then a flush trimming router bit goes through it like nothing.
I've heard you can table saw it, but don't take my word on that one. I haven't tried it.
  • Last login:January 30, 2026, 04:39:53 pm
« Reply #2 on: May 31, 2005, 03:50:11 pm »
Be very careful cutting carbon fiber, especially if you plan on using power tools to do it!  Don't breathe the dust, and pour water as you cut to keep the heat down.
rdagger
« Reply #3 on: May 31, 2005, 04:13:02 pm »
« Reply #4 on: May 31, 2005, 04:54:47 pm »
Isn't WD-40 flammable?  That may not be a good idea...
AlanS17
    • AlanS17
« Reply #5 on: May 31, 2005, 06:28:56 pm »
Unless it's prone to cracking, I'd say get that saw moving as fast as you can and just cut through it as quickly as possible. A slow saw is what will cause splintering.
rdagger
« Reply #6 on: May 31, 2005, 06:57:35 pm »
It's recommended not to use a fast saw because it means more dust.
danny_galaga
  • Last login:Yesterday at 04:05:41 pm
    • dans cocktail lounge
« Reply #7 on: May 31, 2005, 09:32:10 pm »
cut same way you would fibreglass. wear a dust mask. i dont think you need coolant for it but if you do dont get electrocuted!
