Author Topic: Mamewah Setup and Mamewah 1.61  (Read 1322 times)
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« on: May 28, 2005, 04:09:46 am »
I'm in need of some help as I cant seem to get Mamewah setup to work with the "latest" version of Mamewah (1.61). I know it says it will only work with  v 9.54 - v 9.70, but I cant find a site to download those versions from. Minwah's site only has v1.61 available, and when I try to use that in conjunction with Mamewah Setup, I get an incompatibility error.
Where can I get copies of both software that will work together?
Signature tags are dumb.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: Mamewah Setup and Mamewah 1.61
« Reply #1 on: May 28, 2005, 06:08:58 am »
What you need is Screaming's Mamewah Config. http://www.bluecamel.org/2005/02/26/mamewah-config-1611 Works great with the latest version of Mamewah.
