Author Topic: Palette shifts with DirectDraw  (Read 2094 times)
Buddabing
« on: May 26, 2005, 09:58:38 pm »
Hello,
I'm experiencing some weirdness with my cab, which has an ArcadeVGA card installed. When using DirectDraw and MAME, the color palette is wrong. The wings of the green Galaga flagships appear blue, but the white and red look okay. When DirectDraw is turned off with -nodd, the colors appear good but the aspect ratio is all wrong. There's probably a performance hit as well. Colors are fine in front end applications and in the Windows desktop. My DirectX install was the latest (9.0c)
Daphne appears to run okay. Zinc runs okay using the OpenGL renderer, but hangs with the Direct3D renderer.
I just did a soft reinstall of Windows XP Pro and the problem remains the same.
Anyone experienced this? Is there any way to selectively fix just DirectDraw?
Regards,
Buddabing
Please read the wiki!
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
Re: Palette shifts with DirectDraw
« Reply #1 on: May 26, 2005, 10:29:38 pm »
Do you have the latest ArcadeVGA drivers?
Buddabing
« Reply #2 on: May 26, 2005, 11:07:04 pm »
Just the drivers that came with the disk.
I forgot to mention that I have a 7xxx series card.
2600
« Reply #3 on: May 28, 2005, 12:10:51 pm »
What version of MAME?  I've got a similar setup and will try to fire it up and check it out.
Buddabing
« Reply #4 on: May 28, 2005, 12:14:07 pm »
2600
« Reply #5 on: May 29, 2005, 12:46:34 pm »
I tested it, but I want to make sure I'm looking at the same thing.
The flagship is the one who can take your ship, right?
On my regular PC and my cab the wings aren't green, more of a torquoise. I believe this is normal.  -nodd didn't change the color.
My cab has the 7xxx card, WinXP Sp1, and DX 9.0b.   Also from my recollection, the 7xxx series never had a driver update.  Only the 9xxx series, and I want to say they have had or are having a couple updates.
Don't think this really helps.
Buddabing
« Reply #6 on: June 01, 2005, 11:28:08 am »
2600
« Reply #7 on: June 01, 2005, 12:46:42 pm »
That's so odd, I wish we know which part did it, XP SP2, directx 9.0c, or whatever else.  I wonder if screenshots would of captured this error.
Just curious, but was my description correct?  (Correct in meaning I was looking at the right thing and I didn't exhibit the problem)
Buddabing
« Reply #8 on: June 01, 2005, 01:36:18 pm »
