Author Topic: T-molding and laminated top  (Read 3314 times)
mcleanjoel
  • Last login:May 26, 2005, 06:56:52 am
« on: December 05, 2002, 07:39:15 am »
I want to build a control panel with a laminate on top and finish the edges with T-molding.
I prefer not to have to buy a trimmer and trim the edges.
So what is the best combination to use?
3/4 mdf & 3/4 T-molding?
I think this may look Okay but not sure how the edge of the laminate would appear.
5/8 mdf & 3/4 T-molding?
This might be better if it hides the edge but will hang below if I don't trim.
3/4 mdf & 13/16 T-molding?
Probably perfect but hard to find - will cost more and may not get the color I want.
Just wondering what others have done.
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
Re:T-molding and laminated top
« Reply #1 on: December 05, 2002, 08:49:19 am »
www.t-molding.com has 13/16" offset that would work, you would just have to set your slot cutter a little lower...
http://www.t-molding.com/cart/customer/product.php?productid=11&cat=4&page=1
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
dhansen
    • Arcade Stupidity
« Reply #2 on: December 05, 2002, 09:16:03 am »
mcleanjoel
« Reply #3 on: December 05, 2002, 06:00:37 pm »
I have Happ Supers w/red handles and a bunch of red buttons. I was hoping to laminate with black and trim it out with red. Pretty cool colors eh?
Know where I can get red in 13/16?
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #4 on: December 06, 2002, 01:30:35 am »
Not really any help for the size, but I just rec'd 40' of red from t-molding.com and it is sharp-looking against black.  A near perfect color match for some 20year old original buttons I've got, as well as new ones
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
« Reply #5 on: December 06, 2002, 02:56:18 am »
i dont believe you even asked this question :P
For 3/4" wood,you need 3/4 molding.looks 100% perfect as I laminated my cabinet this time.Just wanted to let you know then the result you get with laminate is amezing :o.
mcleanjoel
« Reply #6 on: December 06, 2002, 06:35:10 am »
Snaake,
I think that was what I was looking for - you used 3/4 mdf with a laminate on top (adding around 1/16 maybe?) then used 3/4 T-molding?
Does the edge of the laminate show? Does it look fine? Do you think 13/16 would look better if it covers the laminate edge as well?
This may sound like I am being fussy but I need to order all this and want to know if I am wasting the extra money it will cost if I need to special order it - one place had it cheap but 250 ft min!
Also it seems the 13/16 takes a 7/64 slot bit instead of the 1/16 the 3/4 takes.
SNAAAKE
  • -Banned-
« Reply #7 on: December 06, 2002, 08:36:08 am »
looks fine..take a look at this one.
looks close and you can see it looks fine.
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #8 on: December 06, 2002, 09:19:29 am »
I also used 3/4" MDF and 3/4" t-molding and it looks great.  The edge of the laminate doesn't go above the T-modling as far as I can tell.
ED7
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
« Reply #9 on: December 07, 2002, 01:29:14 am »
even if the laminate does show an edge, if you are using a black based lam, it'll show a black edge all the way though <check a cut bit first in store, some marbles and patterns use  a white or brown base> still, if it does show edge, it'll look like your kitchen/bathroom countertop lip or edge- a tiny racing stripe..:-) <like the above pic.>
a sharp edge on lam is no prob, get a sheet of 320 sandpaper and break the edge..<drag the sandpaer around the edge till the sharpness is gone..a bunch of light passes is all it takes - practice on an offcut till you can get your desired result...:-)>  ends up looking sweet.."=_
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
mcleanjoel
« Reply #10 on: December 08, 2002, 07:52:09 pm »
Thanks for all the advice. I decided to try the 3/4 mdf with 3/4 t-molding so I can stick with standard stuff and get it cheap.
